Author Topic: Broken threads on the transmission fluid drain bolt housing  (Read 2466 times)
Re: Broken threads on the transmission fluid drain bolt housing
« Reply #15 on: December 04, 2017, 07:20:52 PM »
Me?, I'd remove the drain bolt, go to hardware store and look for crushable washer. Something that will seal without requiring you to tighten too much to stop the seeping. These washers are one-time-use...because they deform to seal. Get a couple....
Folks with more experience (I've none)  with these thread repair kits will give the best advice.
