Author Topic: Downtown not starting  (Read 5065 times)
ole two wheels
  • ole two wheels
Re: Downtown not starting
« Reply #15 on: December 18, 2017, 04:15:47 AM »
Hee Hee Mr. Paul. vgrafx Try holding the gas wide open and spinning the motor real good. Then release the throttle completely turn off the ignition and turn it back on, wait for the speedo and tact to finish their swipe and then push the starter, no throttle. See it that helps.
Mac
2012 Kymco DT300
1996 Honda Shadow Spirit 1100
pipster326
« Reply #16 on: December 18, 2017, 08:46:56 AM »
It doesn’t sound any different, on Monday and Tuesday, I actually drove it. Only up the block, I live in an over crowded city, so I actually park the scooter,on the street, so I have a place to park my car when I get home from work. Honestly, it’s been really cold, Wednesday was 28 degrees.  But before that, the battery light was on, while it was running, but then turned off after a few seconds. I just figured that the battery was starting to get weak.
Mr. Paul
« Reply #17 on: December 18, 2017, 10:03:59 AM »
Do you have a trickle charger? Those short trips may not be enough to keep the battery charged.
2009 Kymco People 150
1993 Honda Helix
pipster326
« Reply #18 on: December 18, 2017, 05:25:59 PM »
Yes, I keep it on the battery tender. I’m thinking that it’s something else, even with the new battery, it sounded like it wanted to start, but didn’t, I was just draining the new battery. So I figured I would stop and you guys, before I went anything further
ole two wheels
  • ole two wheels
« Reply #19 on: December 18, 2017, 06:34:31 PM »
Try what I suggested pip. Sometimes my DT 300 acts the very same way and after I go thru the routine I told you about, it starts right up. Only take a moment to try it, what have you got to lose?
Mac
2012 Kymco DT300
pipster326
« Reply #20 on: December 18, 2017, 07:49:51 PM »
ole two wheels, I will definitely try that, I hope it is something as simple as that. It just bothers me, even though it’s been ridiculously cold and snowing and I haven’t taken it out for a nice ride, I hate when gremlins mess with my stuff.
ole two wheels
  • ole two wheels
« Reply #21 on: December 19, 2017, 02:18:42 AM »
I know exactly how you feel.. The reason I said to let you speedo and tact  finish their sweep is that is when the fuel pump is pressurizing your fuel system and your computer is booting up. Mine did the same thing. After I went thru the procedure, It would fire right up, but then I had to kind of work with the throttle for a moment or two, as it didn't want to idle, but that only lasted a very short time and then every thing was back to normal. Can't really explain the why of the matter, but I think it had something to do with trying to start the motor before all systems were on line?? But if are not getting spark, then that opens a whole new can of worms.
Mac
2012 Kymco DT300
pipster326
« Reply #22 on: December 19, 2017, 06:56:41 PM »
ole two wheels,you are the man!!! I did what you said...... and it struggled a bit, but finally started [emoji106]. Thanks so much for the little trick. I ran it for a good 15 minutes and shut it down. It started right back up. I’ll have to wait and see,how she is when I get back. Leaving for Myrtle Beach, for the holidays,Thursday. So until then , Merry Christmas and a Happy and healthy New year to you and your family and all of the forum members as well. Thanks again. Now I can enjoy the holidays!!!
Rich
« Reply #23 on: December 19, 2017, 07:26:44 PM »
The prize goes to Mac! Hoist him on your shoulders, mates! Well, drag him then. Get him close to the podium so we can give him the award! Flooded start procedure. Whoda thought!
pipster326
« Reply #24 on: January 29, 2018, 09:00:17 AM »
We had some really nice weather in Jersey on Saturday. So I went to start the DT to go for a little ride. Would it start again!!! I’ve had the new battery on the tender, I tried Mac’s procedure, and would not turn over. I decided to check the plug. When I took it out, the one end was black and loaded with carbon, the other end was bent,almost at a 90 degree angle. I have not changed that plug in over a year and a half, have no idea how it bent. I put the stock plug back in and it started right up. Drove for an hour and everything was fine. IDK
stuo
« Reply #25 on: February 05, 2018, 10:23:42 PM »
It's interesting how times have changed. Back in prehistoric times the first thing to inspect with a problem like pipsters' was the spark plugs because they often fouled out due to the leaded gas, flooding, excess oil consumption, weak spark, wrong gap, etc. Nowadays, what with unleaded gas, EFI, ECU and closer engine tolerances, spark plugs are good for so many miles we now overlook them as the culprit, or as a diagnostic tool, especially when it is not easy to access them, as is the case in our scooters.
2009 GV 250
