Author Topic: MXU300 only has reverse  (Read 2013 times)
Joshwfl
« on: December 09, 2017, 04:11:59 PM »
Josh here from the sunny state of FL.  I'll start by saying that I've been maintaining my own machines for 30 years, so I know my way around an engine.  I've always had chain driven sport quads though, my only CVT is on my Rhino, and I've never owned a Kymco.  I just bought an 09 MXU300 as an upgrade for my son for a steal.  It's super clean and starts right up, but will only go into reverse. I pulled the linkage off and shifted the transmission by hand.  It would still only catch reverse.  When the machine is off, I can put it in H or L by hand and feel/hear the transmission spinning. Neutral works fine.  If I hand shift it into H or L when running, it rolls like it's in neutral.  If I add throttle, there is no noise or movement.  If I roll it forward or back with slight throttle while in gear and running it sounds like something is binding.  I'd appreciate any suggestions before I start tearing it apart!
Re: MXU300 only has reverse
« Reply #1 on: December 11, 2017, 01:36:51 AM »
Not ignoring you. I don't think anyone has taken one apart yet. Airshot may have.
Joshwfl
« Reply #2 on: December 11, 2017, 02:38:51 AM »
Hey, any response is a start...I appreciate it!  From what I see, it's the same engine as the Arctic Cat Alterra 300.  I've been looking at some fiche, I'll probably pull the gear case tomorrow and have a look.  I know the linkage is off a bit because it would light neutral in reverse, but that doesn't explain not grabbing a gear with the linkage off.
corneredge
« Reply #3 on: February 11, 2019, 06:08:44 PM »
I have a Mxu150 just started this issue, seems to be stuck in reverse like the linkage shfted... I have to put it in forward to get to neutral now.  Did you ever figure out your problem?
