Author Topic: Kymco people 50cc 2t 2004 gear vent or?  (Read 1570 times)
bulgarian_boy
« on: January 17, 2018, 06:55:46 PM »
Hello everyone. I found this hole in the carter, and sometimes running oil out there. what was there in place of this hole? Does anyone have a photo to show me? Kymco people 50cc 2t
Thanks
« Last Edit: January 18, 2018, 06:12:45 AM by bulgarian_boy »
kymco people malossi sport 70cc two stroke,carb 19mm #90 main jet  , leo vince sp3 pipe , variator koso , yellow springs malossi , 6.5grams rollers weight , max speed 105km/h
Re: Kymco people 50cc 2t 2004 gear vent or?
« Reply #1 on: January 17, 2018, 08:12:23 PM »
Can you move back a bit with the camera? Maybe some of the 2t experts here know what this is and where it it is.
bulgarian_boy
« Reply #2 on: January 18, 2018, 06:14:59 AM »
I hope this pics will help
flhouser
« Reply #3 on: January 19, 2018, 06:19:41 PM »
I'm no expert, but it might be the final reduction level / filler.  You might take a look at page 9-8 of the manual
www.sciitermasters.com/manuals/kymco%20People%2050-complete.pdf
Sent from my moto x4 using Tapatalk
flhouser
« Reply #4 on: January 19, 2018, 06:22:56 PM »
Should be scootermasters.com
http://scootermasters.com/manuals/
« Reply #5 on: January 19, 2018, 11:39:03 PM »
Flhouser link to service manual subtly shows on page 9-7 that hole which is the vent for the gear box. It will weep a little during normal use but will weep A LOT if you overfill the box. This is something most of us have done because you do NOT fill to the fill hole. That manual also  specifies how much oil should be used. I recommend you drain and refill with the correct amount to be sure.
bulgarian_boy
« Reply #6 on: January 20, 2018, 05:55:37 PM »
thank you all for your help. :)
« Reply #7 on: January 20, 2018, 09:27:15 PM »
Anytime! Keep coming back!
