Author Topic: Kymco battery problem  (Read 3221 times)
Grumpet
« on: January 22, 2018, 05:33:18 PM »
I am grumpier, proud owner of  one kymco 300 downtown.
A few  days ago my battery went totally flat, it's partially my fault due to not using it and lot, and I want to buy a new one which one should I buy? : I found two types maintenance free and with acid. I tend to lean toward the maintenance free but I am not sure about the type of battery to buy.
Any help is appreciated, I live in the UK but I am not from there so I don't know where to buy a battery
pipster326
Re: Kymco battery problem
« Reply #1 on: January 22, 2018, 06:21:45 PM »
I just replaced my stock kymco battery,on my 2012 Downtown 300i. It was a kymco GT12a-bs. It is really your choice of which battery you prefer,just make sure that it’s the same size. Here in the states,there are many places to get a replacement battery. Any motorcycle or scooter shop,should have them in stock. Online,they run about $25-$30 USD. Not sure what the mark up is at a shop.Also,once you get the battery,make sure to get a battery tender,to keep it charged,especially if your not using it on a regular basis
Grumpet
« Reply #2 on: January 22, 2018, 06:50:54 PM »
Thanks for the reply, so the correct battery is yt12a-bs?.
I have also been given by a friend a YTX12-BS battery, is this one OK for size, voltage etc  for the kymco downtown 300?
Also to every battery I buy, must I add acid?
« Last Edit: January 22, 2018, 06:52:31 PM by Grumpet »
pipster326
« Reply #3 on: January 22, 2018, 07:55:05 PM »
That battery should work, as long as it fits in the battery compartment, even if it is a little bigger, it’s gonna be a pain to get it in. I believe that battery is maintenance free, so you don’thave to add anything
Grumpet
« Reply #4 on: January 22, 2018, 08:09:11 PM »
I asked about the acid because the battery I ordered from amazon arrived with electrolytes to add{sulfuric acid} then seal it and its ready. Do I need to charge it before, or can I use it straight away?
« Reply #5 on: January 22, 2018, 09:29:19 PM »
you can check if it needs a boost , put a charger on it , If  it charges leave it for 12 hours, It will take about a week of riding to get the battery to full charge, they need to learn just like kids,  like tires need to be broken in when new,  about 100 miles,.
Grumpet
« Reply #6 on: January 22, 2018, 09:34:14 PM »
As soon as the yt12a-bs (yes I ordered one to be sure} arrives I will try it with the scooter.
Since my scooter battery  "died" at friends place, I'll have to put it without charging, I need to bring the scooter home.
I will try to charge the battery later on.
Thank for the helpful advice
Trucker jay
« Reply #7 on: January 29, 2018, 09:31:57 PM »
Every battery that I had to add the sulfuric acid needed charged before use
« Reply #8 on: January 29, 2018, 10:51:13 PM »
YUASA battery from AMAZON, come charged and sealed, can be laid on side (as in a Burgman 400)
mousejunks
« Reply #9 on: January 30, 2018, 09:12:36 AM »
I had a Motobatt MBTX-9U, ran for a few years before the regulator failed and it went flat.
'09 Kymco Espresso 150i
'17 Kymco Downtown 350i ABS
wheels
  • USA, NC, Raleigh
« Reply #10 on: January 31, 2018, 12:23:01 AM »
Here is what I have for batteries.
Battery         Kymco  GT12A-BS,       Xtreme  XTA12A-BS
Replaced with the Extreme which looked identical, but I could not squeeze it past
the security (brass colored) brackets.   I took an angle grinder and cut some of the
bracket off.
2012  DT 300i  26K miles,  Bestem 929, Biondi w/s, LED brake/tail,turn, OEM mirrors fairing mount, removed buttstop
2015  GTi300  7K miles, Bestem 929 case, PUIG TS w/s, mirrors mounted to w/s, led DRLs in windguards
2014  Honda CTX700,  35Kmiles, many mods
Tromper
  • Seattlish
« Reply #11 on: February 02, 2018, 12:48:02 PM »
How'd it go Grumpet?
You get it home and charged?
2008 SYM HD200 "Niwanibiz"
k9 S200 (Blue) "Max" (Sold)
Grumpet
« Reply #13 on: February 05, 2018, 08:37:17 PM »
i Apologize for the delay, the scooter is fine i just used the yuasa battery.
1)opened the scooter
2) put in the battery
3) Profit
