Author Topic: crazy gas gauge  (Read 2630 times)
codger78
Re: crazy gas gauge
« Reply #15 on: July 21, 2010, 10:33:41 AM »
Sidthesloth and all..Thanks...Just floating an idea...have not even looked into that hole yet...will let you know how the whole thing turns out.
borrowed dust
sidthesloth
  • Kymco ZX50
Re: crazy gas gauge
« Reply #16 on: July 21, 2010, 12:26:21 PM »
All the best, whichever way you go. Keep us posted.
mikrron
  • at least outstanding !
Re: crazy gas gauge
« Reply #17 on: July 21, 2010, 03:40:23 PM »
my gas gauge was defective from factory so when i dissmounted the side pannels i gave a look in the tank also.
inside is a a pice o wire and a mechanism with the flotor attached to it. all u need is to tighten/loosen the wire by hand so the flotor can move better.
that`s all..and don`t forget the position it has inside the tank
PS 10.000 km on my scoot now :D
sorry for my writing mistakes .. i`m only human
esellie
Re: crazy gas gauge
« Reply #18 on: July 28, 2010, 08:28:56 PM »
I also have a crazy gas gauge problem.  I just bought my Agility 50 with 127 miles on it and the previous owner said the gauge didn't work.  I've found regardless of how much gas is in the tank that the gauge goes back and forth between either completely full or completely empty and nothing in between even when I have only a half a tank.
jbcinzio
  • I was the second gunman on the grassy knoll....
Re: crazy gas gauge
« Reply #19 on: July 28, 2010, 09:00:21 PM »
Nice ride Mikrron, Love the colour  8)
Josh
This message was posted using 100% recycled electrons.
codger78
Re: crazy gas gauge
« Reply #20 on: July 29, 2010, 12:23:49 PM »
esellie....The float should "float".....Try pressing down on the float when the tank is full (assuming that the float is in fact floating at the top of the gas).  It should bob up and down as you press on it.....If it does not then the linkage is probably hanging up or loose or the float has been punctured.  If it does, check your wiring.
borrowed dust
jay20
Re: crazy gas gauge
« Reply #21 on: August 03, 2010, 02:48:44 PM »
i have a 06 agility 50 n the fuel gauge does not work at all anyone have any ideas on how to fix it?
codger78
Re: crazy gas gauge
« Reply #22 on: August 19, 2010, 09:03:31 PM »
Bringing you up to date:
I gave up the idea of bending the float arm to improve the accuracy of the gas gauge partly because I can't get at it easily, but also because in fact it moves from the very top of the tank when full to a point where it can't seem to be pushed down any farther (and where the gas needle is pointing through the middle of the "E")......but at which point I was still able to siphon out a bit more than a liter and a half of gas (during which the needle had not dropped any farther).
In the city and suburbs I get about 93 mpg (high test) and about 100mpg in the exurbs and beyond..........when the needle reaches the low point after having traveled some 80 miles in town, that means that I have about another 40 miles remaining before I HAVE to get more gas.
I guess it's better not to tempt fate, the numbers, or your memory.  When you notice that the needle is at the lowest point, STOP AND GET MORE GAS.
« Last Edit: August 20, 2010, 01:08:04 AM by codger78 »
borrowed dust
Re: crazy gas gauge
« Reply #23 on: August 19, 2010, 09:50:24 PM »
...mine still has quite a bit left in the tank when registering 1/8" below E...
..kinda like that....
sidthesloth
  • Kymco ZX50
Re: crazy gas gauge
« Reply #24 on: August 20, 2010, 11:27:19 PM »
Yeah, I like that too, when I start panicking about getting home for fuel, I always make.... so far anyway. I like the 80 miles on a tank, I am at 80 kms. The price we pay for fun, (about $4 a tank) ;)
