Author Topic: down town 300 Windshield fix  (Read 2221 times)
stuo
Re: down town 300 Windshield fix
« Reply #15 on: March 12, 2018, 07:13:11 PM »
A new windscreen for your DT is around $100 from Leeson's.
2009 GV 250
ModChiP
« Reply #16 on: March 12, 2018, 09:44:38 PM »
i live in Israel, and the shipping is very expensive.
maybe i can found something local.
tnx!
« Reply #17 on: March 12, 2018, 09:54:06 PM »
Your local guys should be able to curve 1/8" (3 mm?) polycarbonate (Lexan) and trim to work. I have a deburring tool from Israel I used in aircraft work so your airplane guys should be able to tell you where to get polycarbonate (not Plexiglas or resin!) and who can work it. Polycarbonate is more expensive than resin in the US and must be there, too. Overall, making one will probably be less than shipping.
ModChiP
« Reply #18 on: March 12, 2018, 10:01:49 PM »
to make one, its about 120$ minimum.
stuo
« Reply #19 on: March 14, 2018, 07:54:38 PM »
Perhaps you could cut off the top half and epoxy/bolt a new piece of plastic to the lower half? The big problem is the sharp curvature of the DT windscreen. I've read that you can put plastic in the oven and bend it when it's hot.
I use my grinder with a 1/8th inch metal cutting disc to cut across windscreens, using masking tape for a guide. Don't use a saw, the screen will shatter.
In any case, I'd have at least a three inch wide glue/ bolted joint where the pieces mate. You wouldn't want the new top half to fly off at 70 mph. I guess the question is: Do you want to see...or stay out of the wind?
On ebay you can buy an adjustable plastic wind deflector for $20, postage paid from China, with hardware, that you clamp  to the top of the (now cut down) screen and you can see through it. I dunno if that $20 includes postage to Israel, though.
I recently bought a new, Kymco factory-made windscreen that was a perfect fit for my Downtown 300i from Leeson's for around $100. They are at https://www.leesonsarcticcat.com/contactus.htm. I have found them to be the cheapest and most helpful providers of Kymco parts. Ask for Lee if you call them.
Good luck.
2009 GV 250
ModChiP
« Reply #20 on: March 14, 2018, 10:45:54 PM »
TNX!
kneeslider
« Reply #21 on: March 16, 2018, 06:38:15 AM »
I saw no pictures the first time! Ow! I don't know if that "crazing" can be rubbed out! Replace with something from the Italians would be the best.
Hi. Similar case I have with my DT.
Micro cracks in the polycarbonate windshield. There is no fix but to replace.
Sent from my HUAWEI VNS-L31 using Tapatalk
2019 Yamaha X-Max 250
