Author Topic: Raising front light beam.  (Read 1693 times)
fest
« on: March 13, 2018, 12:07:50 AM »
Does anyone know how to raise front light beam. There is a screw just underneath it, i tried turning it right but it doesn't seam to work. Any suggestions?
Re: Raising front light beam.
« Reply #1 on: March 13, 2018, 10:41:24 AM »
Check owner's manual. .....but turning scooter headlight adjustment screws to the Right usually lowers the beam.
Manual should show you where the adjustment device is located.
Need owner of your scooter model to chime in here.....
fest
« Reply #2 on: March 15, 2018, 12:02:45 AM »
I've checked owner's and service manual nothing there. Tried turning the screw to the left but don't see any difference will double check. Thanks.
« Reply #3 on: March 15, 2018, 12:36:13 AM »
Surprised a People 300 owner hasn't responded.
Generally tightening the screw below the headlight pulls down the headlight bucket - lowering the beam.
Loosening the screw should push up the aim.
My light aim moves only a little at a time....but I don't have your scooter.
I aim it at a wall and place tape on wall to mark my starting point.
« Reply #4 on: March 15, 2018, 01:38:57 AM »
We have one but never got into that. I would bet it is like all headlight adjusters: it is long-winded! Takes a BUNCH of turns to see any difference. That's why Stig says use a piece tape! He a smart guy!
wheels
  • USA, NC, Raleigh
« Reply #5 on: March 23, 2018, 01:09:11 AM »
Ditto, Crossbolt.
As I remember it actually moves the reflector not the lens.
Take your time and go easy, it will adjust.
2012  DT 300i  26K miles,  Bestem 929, Biondi w/s, LED brake/tail,turn, OEM mirrors fairing mount, removed buttstop
2015  GTi300  7K miles, Bestem 929 case, PUIG TS w/s, mirrors mounted to w/s, led DRLs in windguards
2014  Honda CTX700,  35Kmiles, many mods
fest
« Reply #6 on: March 23, 2018, 09:50:11 PM »
Thanks for your help. Visually you can't see anything as you are turning the screw. That's why I was puzzled and thought it wasn't working. As you mentioned it's best to do at night against the wall or something.
