Author Topic: Regulator  (Read 5013 times)
Re: Regulator
« Reply #15 on: May 15, 2018, 10:40:45 AM »
That was one thing I could never get sorted whether the 232-12 was shorting or open. But guessing with that black wire it is open which is easier on the stator! You could run a separate wire from the ECU relay or nearly any relay to get that ignition on signal. Just use one of those push-on lug "branch" fittings.
szabgab
Re: Regulator
« Reply #16 on: May 18, 2018, 08:23:46 PM »
Now then... I'm happy to report,  that the transplant worked out brilliantly,  a battery measuring 12.5-12.6 is being charged at 13.5-13.7 at different throttle positions,  I will see,  how much current goes into a fully charged battery.  It was a bit of a bit©h to put the new stator on -  first the connectors gave some trouble and the mounting holes do not line up,  which would have been less of an issue,  if I could have gotten the rear spoiler off,  but the top box holder and it's bolt is rusted together so much,  I have rounded up all allen heads,  even after repeated attempts of penetrating oil treatment and heat. Eventually I will drill off the bolts,   but now I couldn't have arsed,  so I had to attach the stator with the spoiler in place,  it must have been a wonderful sight of me trying to bend my arm into unnatural positions to reach inside.
Re: Regulator
« Reply #17 on: May 18, 2018, 09:49:53 PM »
New stator? I thought you put a reg-rectifier on.
szabgab
Re: Regulator
« Reply #18 on: May 18, 2018, 10:03:12 PM »
Of course you are right,  I'm just a bit too tired and writing stupidities :)  I put in the 232 after some modifications and it works like a charm :) Now, I'd like to know,  why I reused the old and cracked gasket on the generator cover??  Obviously I hav an oil leak,  damnit...
« Last Edit: May 19, 2018, 07:00:19 AM by szabgab »
Re: Regulator
« Reply #19 on: May 19, 2018, 01:44:20 AM »
 ;D ;D ;D
szabgab
Re: Regulator
« Reply #20 on: May 25, 2018, 09:23:38 PM »
So, just a quick update to anybody, who is considering the SH transplant - The bike is charging the battery beautifully, and a fully charged battery gets 14.2-14-4 Volts at idle. For the 20-ish USD I paid for it at the junkyard, I could have most likely bought a direct bolt-on Chinese replacement, but I do trust the old Honda stuff a lot more, than something, that could probably fry my stator, battery or both
Re: Regulator
« Reply #21 on: May 25, 2018, 09:49:34 PM »
 :) ;) :D ;D 8) ::)
