Author Topic: coil help  (Read 2249 times)
Macnerd77
coil help
« on: April 13, 2018, 02:32:45 AM »
Hey all I recently purchased a 2007 Kymco ZX 50 Super Fever Scooter. I decided to give it a tune up so I went about replacing the spark plug and coil along with cleaning the air filter. I am having issues with the coil. It seems to be too long where it connects to the spark plug. When I sit on the scooter the components above contact the coil connector and bend and crack it at the spark plug. Do I need a short spark plug or is there a special coil that is shorter? The mistake I made during all this was throwing out the old coil and plug without looking at them thoroughly to see if they were different than the one I bought.
Thanks in advance
Re: coil help
« Reply #1 on: April 13, 2018, 11:27:26 AM »
Can you locate an exploded parts diagram from online seller to get a look at the coil....and correct spark plug?
eamartin
Re: coil help
« Reply #2 on: April 13, 2018, 02:17:50 PM »
Parts diagram shows what appears to be a 90 degree cap rather than the 45 degree cap shown in the photo.  Would the different angle solve the problem?  Since your cap is now broken, can you buy a new cap and just shorten the wire as needed?
Re: coil help
« Reply #3 on: April 13, 2018, 07:49:31 PM »
You have bigger problems with the cooling shroud being all busted up (on the left side in last picture). Looks like previous owner  or his tech mangled things.
Viper254
  • Moped Pirate
Re: coil help
« Reply #4 on: May 03, 2018, 08:15:27 AM »
Agreed, that'll cause seizure in the long term and should be a #1 priority to put right. Forced air cooling only works when the shrouds are in good order!
Rides;
Suzuki GW250 Inazuma (2016)
Honda C70C (red, 1983)
