Author Topic: xciting 500 instrument cluster problems  (Read 2575 times)
Scootmaster
  • If you're too busy to ride, you're too busy!
« on: April 25, 2018, 02:42:20 AM »
I recently aquired a 2009 xciting 500ri. It runs great but the guage cluster doesn't work. The back lighting, trip odo,clock,turn, hi beam indicator all work but none of the guages, tach,speedo, fuel, temp do not. The battery light and cell phone light stay on. Any ideas? I'm pretty certain it's going to be the cluster itself but I'd like to know it's not a problem in the wiring leading up to the guages before I have to spring for a new one, if I can even find one. Any help would be greatly appreciated.
2011 Kymco People 50
2009 Kymco Xciting 500Ri
2004 Honda VTX1300S
2008 Honda Goldwing GL1800
Re: xciting 500 instrument cluster problems
« Reply #1 on: April 25, 2018, 02:10:33 PM »
I will bet there is more than one plug/connector into that cluster and one has worked loose.
Scootmaster
« Reply #2 on: April 26, 2018, 03:09:52 AM »
I've removed the cluster and there's one 24 pin connection. I looked for cold solder joints and even resoldered ones that looked questionable but no change when i hooked it back up.
2004 Honda VTX1300S
« Reply #3 on: April 26, 2018, 03:14:56 PM »
I lost the bet, dint I! The next step is probably inside the cluster. A couple of guys on here have opened their instrument clusters and repaired them rather than part with the bucket of cash needed to replace the whole thing. You may want to check all the grounding points first because bad grounding could produce your symptoms.
Scootmaster
« Reply #4 on: May 12, 2018, 03:47:46 PM »
Problem solved! I bit the bullet and bought a new cluster. Btw, the old one looks cool hanging on my workbench peg board. I'll post some pics after I study the schematics and run some Vdc to the backlight connector. Lemons to lemonade!  ;)
2004 Honda VTX1300S
« Reply #5 on: May 12, 2018, 05:45:29 PM »
