Stig, first service at 200 miles, second at 600. Below are the steps written in the manual for the first one:
200 MILES / 300 KM
Engine Oil - REPLACE
Engine Oil strainer - CLEAN
Gear Oil - REPLACE
Spark Plug - CLEAN
Valve Clearance - ADJUST
Carburetor - INSPECT
Air Cleaner (filter) - CLEAN
Battery - INSPECT
Brake System - INSPECT
Tires - INSPECT
Bolt & Nuts - TIGHTEN
Valve clearance adjustment and carburetor inspection: the only reason I'm considering to do the service at the dealership, as I don't have the tools and much knowledge to do it. Everything else is pretty simple and would cost me less than $20 and maybe 30-40 min of work!
For the 600 miles service, manual recommends only engine oil change and to inspect spark plug, air filter, battery, brakes, tires, bolts and nuts. At least this one I can do by myself.
Jmerr Yeah the only reason I'm considering to pay for it is because of the valve clearance adjustment and carburetor inspection. Everything else is pretty simple and easy to do
Youtube valve adjust of a Super 8, by forum member
I have just never heard of a dealership that will pull the spark plug, clean the airfilter and strainer, drain and fill the engine and gear oil, look at the tires and battery (?), re-torque important fasteners, AND remove the plastics to remove the valve cover and check the valve clearances...... no matter the mileage....for $120. !!
Again - unless that is for all practical purposes a "freebee" service to the new owner provided by the this very rare dealer?
I get that all the rest will be done - then they will
listen to the engine to see if there is valve clatter. And of course at 200 miles it will sound fine - as it will at 600 miles.
No one that I know of has ever pressed a dealership by asking, "
Did you really check my valves?"
But, you know what?.....I have also never heard of a young scooter that grenaded because the valves were off. Never. Not in any forum. None.
I'm not saying that scooters don't need valve adjustments --- and I've only been goofing around with scooters for 5 years - ( a Honda Forza 300, a Suzuki Burgman 400, a Piaggio 155 and a Kymco 163) but I've come to the thinking that valve checks are most often needed more by the owner, than the scooter.
So, I say - let them do the service. Get it logged in the scoot's service record. The valves will be fine, either way.
Do the other stuff yourself per the schedule in the months and years to come - and give some thought to learning to do your own valve checks in the future.
