Author Topic: Wired Kymco Super 8 150 mojo  (Read 727 times)
Jmerr17
« on: April 28, 2018, 04:02:44 AM »
Ok here's an update I checked my valves and they were in excellent working condition and the only dilemma I have should the intake be set at
 .004 and the exhaust .005 or .004 for intake and .004 for exhaust :"Note my carb is a 28mm also I have a shorty muffler"..... I notice after trying to start the engine it tries to turn over but "no go" and I also notice there's no fuel flow to the carburetor. The wierd thing I checked the fuel pump by adding vacuum to the vacuum hose and it had fuel flow. I then removed the fuel hose to the carb and applied vacuum to the vac house and I had fuel flow then reconnected the fuel house to the carb and again I applied vacuum to the vac hose and no fuel flow to the carb..I need big time suggestion..
What the (×#*%÷&@) is going on!!!
Sent from my LG-H918 using Tapatalk
