Author Topic: Handlebar grips  (Read 1354 times)
Dsoul82
Handlebar grips
« on: May 02, 2018, 06:24:17 PM »
Hello,
i want to change handle bar grips. On right side is need to unplug speed wire.  Can somebody know how to open this on picture? It will be enough  for changing right grip?
I want put new original Kymco grips.
Thnx
Br
Re: Handlebar grips
« Reply #1 on: May 02, 2018, 07:59:13 PM »
Screws on the bottom, I think...
kneeslider
Re: Handlebar grips
« Reply #2 on: May 03, 2018, 12:43:37 AM »
Yes. Two phillip head screws at the bottom.
Refer to picture.
Sent from my HUAWEI VNS-L31 using Tapatalk
2019 Yamaha X-Max 250
Viper254
  • Moped Pirate
Re: Handlebar grips
« Reply #3 on: May 03, 2018, 08:06:31 AM »
Are you removing the throttle tube or changing the grip?
If you're only changing the grip, you don't need to remove the throttle tube as well :)
Rides;
Suzuki GW250 Inazuma (2016)
Honda C70C (red, 1983)
Dsoul82
Re: Handlebar grips
« Reply #4 on: May 03, 2018, 03:09:46 PM »
I want to replace only grip but original grip is with tube.
Is it possible remove only grip without tube? without destroying grip.
Re: Handlebar grips
« Reply #5 on: May 03, 2018, 03:16:45 PM »
The grip, the rubbery part, is securely glued to a plastic tube with some kinda atomic force glue. There is a post on here somewhere with pictures of the huge steps one of our rider-owner-pioneer posters had to go through to try and remove the rubber part.
kneeslider
Re: Handlebar grips
« Reply #6 on: May 03, 2018, 03:19:38 PM »
I tried to remove the grips from the tube. It is impossible. Ended up buying an aftermarket quick turn throttle tube with Spider grips.
Viper254
  • Moped Pirate
Re: Handlebar grips
« Reply #7 on: May 04, 2018, 07:00:11 AM »
I just cut the old grips off... so no :(
Rides;
