Author Topic: Valve Stem Hole Size  (Read 563 times)
TLRam1
« on: May 02, 2018, 06:34:01 PM »
Replacing my rubber stems with aluminum, do you know what size hole is in the rim?
The stems I want are 11.3 MM, do you know if these will fit? If it matters I run a 250 S People.  One catalog list these as Japs are 11.3 and Euro & aftermarket are 8.3 MM.
Terry
10 Kymco People S 250
87 Yamaha Riva 200 (Sold)
Allen TX (Dallas)
cli-maxridinggear.com
FrogmanDave
Re: Valve Stem Hole Size
« Reply #1 on: May 03, 2018, 02:09:33 AM »
I just replaced some on my People 150 rims. The stems were listed as 11.5 mm on Amazon. I'm pretty sure yours will be the same.
TLRam1
« Reply #2 on: May 03, 2018, 02:36:35 AM »
Yes I would think they are the same on most all the Kymco line, thanks for the input.
Terry
Allen TX (Dallas)
TLRam1
« Reply #3 on: May 05, 2018, 07:38:57 PM »
I ordered these angled Red ones, we will see how they fit. If you have never had solid mount angled stems (not the ones that are snapped in and held by the rubber bottom part of the stem), you would be in for a pleasant experience, much easier to check tire pressures and add air.
« Last Edit: May 05, 2018, 07:44:21 PM by TLRam1 »
Terry
Allen TX (Dallas)
