Author Topic: GPS Vehicle tracker GPS303B.  (Read 771 times)
ModChiP
« on: May 11, 2018, 01:54:01 PM »
i just bought this device
https://www.ebay.com/itm/GPS-Vehicle-tracker-GPS303B-TK303B-LBS-GPS-location-geo-fence-No-Original-Box/281749788669
where should i hide it?
in the front headlight unit or in the back under the seat near the battery?
Re: GPS Vehicle tracker GPS303B.
« Reply #1 on: May 11, 2018, 02:11:44 PM »
Front. There is that skinny wire that goes to the 12v outlet in the "glove box" that could be used for the ACC lead and there is the access to 12v always hot at the ignition switch. I missed seeing any current drain on that fused 12v lead.
ModChiP
« Reply #2 on: May 12, 2018, 12:09:00 PM »
then to access the gps i need to take apart all the front.
szabgab
« Reply #3 on: May 12, 2018, 04:02:17 PM »
Taking the front apart is seven screws undone and three connectors unclipped, not a big deal. Since owning my troublesome Xciting, I have done it so many times, it takes me roughly 30 seconds :) But given this, at least you can rest assured, that unless the nicking bastards brake the bike to parts immediately you stand a good chance of them not finding the tracker and throwing it into the nearest bin.
Besides, if it is in the front cowl, the antenna is shielded only by a thin layer of plastic, rather than plastics, the seat, probably interference from the battery or other electrical equipment
« Last Edit: May 12, 2018, 05:25:07 PM by szabgab »
« Reply #4 on: May 12, 2018, 05:44:10 PM »
What Gab said! Yes, you would have to remove the front even if you just wanted to put it in that glove box. UNLESS you plugged it into that outlet everytime you parked the bike. What about one of those 'Tiles' and a phone app they were peddling recently? I think the Tile is always on and you replace the battery once a year.
hypophthalmus
« Reply #5 on: May 12, 2018, 06:34:20 PM »
I was assuming the point was to find it again in case of theft? In which case I would think it'd be better to put it somewhere less accessible.
Why would you want to be able to casually remove it?
I think even if they found the unit, the tracking information would still have already been uploaded. Assuming they stay within range of the GSM network.
« Last Edit: May 12, 2018, 06:40:11 PM by hypophthalmus »
