Well, I may have cured most of my "missing" problem at high cruise speeds. Reading the owners manual as well as info on the internet, I was under the impression I should be using high octane gas. Well, duh, looking under the seat I find a very clear label that said use 87 fuel. I switched.
Almost immediately, first tank, my bogging, surging or missing was greatly reduced. On tank 5 of regular, branded gas now and is running so much better. Every now and then, when cruising between 55-60, straight and level, it will "miss" but nothing like it used to.
Next I will change the spark plug and check the valves. Other than this little problem, Scarlett runs like a champ.
