Author Topic: Calling All Experienced Tuners!  (Read 1183 times)
Magoconnor
« on: May 18, 2018, 02:02:08 PM »
Hello.
I am writing to you about some problems I have with my scooter.
Kymco super 8 4 stroke 72cc.
I hope you guys can help me out.
My scooter do not really reach high rpms when I give it full throttle, as you can hear in this sound clip
Which in turn limits my top speed..
I have removed the following restrictions:
Cut one of the small wires at the cdi box.
New sliding tube and new polini variator 4.5 gr.
In addition to a 72cc bbk I've also fitted a larger cylinder head with bigger valves. I have had to increase my main jet size, following the installation of the new bigger cylinder head. Right now I'm running with a 110 which I think is pretty high. I have also tried higher and lower main jets with no increase in performance. The rpm does not go up nor does the top speed.
I have thoroughly checked for leaks but found none.
The scooter starts immediately and keeps idle fine.
Timing is correct and valves are adjusted.
My setup:
72cc gy6
47mm cylinder head 21 in / 19 out
Performance camshaft
Polini variator 4,5 gr
Unifilter
Leovince exhaust
15% stronger torque spring
Stock carburator
AylmerFreerider
Re: Calling All Experienced Tuners!
« Reply #1 on: July 18, 2019, 08:38:33 PM »
I have a similar set up and I only put a 92 jet in the carb.
I also have 6.5gr weights and I am hitting 7800 rpms.  These are meant to hit a power band at 7400-7600 rpm.
I would look into gettin and installing a tachometer just to make sure.
2015 Super 8 50R
72cc BBK
Polini Hi-Speed with stock boss and 6.5gr rollers
Naruko 1000RPM White Spring
Technigas Silent Pro Exhaust
3 x 1" Air Filter additions to Air Box
