Author Topic: utv has power to the injector  (Read 801 times)
Red Good
« on: May 24, 2018, 05:15:07 PM »
wont open . what can I do , should be a ground signal right , so if I ground one side it should trigger the injector . Any ideas ? let me know .
Re: utv has power to the injector
« Reply #1 on: May 27, 2018, 10:11:29 PM »
How do you know the injector will not open?
Red Good
« Reply #2 on: July 06, 2018, 05:08:28 PM »
no fuelm  to the motor ? ground the not hot side with every thing powered up have fuel pressure at the injector and good spark and compression just no fuel . any ideas
Red Good
« Reply #3 on: July 06, 2018, 07:02:02 PM »
This thing ran fine even with a busted tranny , rebuilt it and motor back in frame and has good spark and will run if I drip a bit of gas in the injector hole . but  will not trigger the injector . Where does the injector get its signal , from the ecm . what are the triggers that make it possible ?
Red Good
« Reply #4 on: July 09, 2018, 07:55:56 PM »
Anyone have a wiring diagram for these ?
