Author Topic: That oil strainer screen  (Read 1017 times)
« on: May 29, 2018, 11:43:16 PM »
Still never found anything in this screen - except a couple small bits on the first oil change which I did after the first 60 miles.
The big cap is a very soft metal - and after overtightening them some owners destroy them in attempts to remove them.
Spares are available on ebay for a couple of dollars. I take it easy when tightening this cap, and use a new Toyota Teflon/metal washer on the drain plug. (bag of 10 for @ $3.00 on ebay)
Used 10W-40 Suzuki "Performance" oil left over from the Burgman. Have a gallon jug of it.
Cleaned off the bottom of the engine and re-applied some ACF-50 to the engine area, center & side stands and these drain fasteners. Drained the puke tube and lubed both stands. Gave the muffler a squirt of heat paint.
Will do the gear oil when it rains next. Too hot today!
Viper254
  • Moped Pirate
Re: That oil strainer screen
« Reply #1 on: May 30, 2018, 07:04:53 AM »
The sump plugs are really soft, but I'd rather have a soft plug than accidentally strip the threads from my engine!
Always worth carrying a spare :)
Rides;
Suzuki GW250 Inazuma (2016)
Honda C70C (red, 1983)
big blue
« Reply #2 on: May 30, 2018, 04:43:43 PM »
I purchased a 6 point box end combination wrench just for that plug after reading so many "I stripped my drain plug" posts. I still have both original plugs installed.
Tromper
  • Seattlish
« Reply #3 on: May 30, 2018, 09:51:31 PM »
Still never found anything in this screen - except a couple small bits on the first oil change which I did after the first 60 miles....
Been my experience on a few scoots as well.  I've seen a couple pics, notably in chinascoot forums, where there's been a lot there on new bikes, & on a bike that was developing problems.
2008 SYM HD200 "Niwanibiz"
k9 S200 (Blue) "Max" (Sold)
« Reply #4 on: May 30, 2018, 10:19:29 PM »
At this point, after 5 yrs, I think I'll quit fooling with this....nothing ever in there...just inviting a leak to develop.
Considered not removing it this time, but decided to have a look.
Probably not again.
Maybe 3 tablespoons of old oil in there.
As often as I change oils - 600-800 miles using good brands of oil.
A bit of old is not an issue in my mind.
Tromper
  • Seattlish
« Reply #5 on: May 31, 2018, 01:46:38 AM »
I don't pull it every oil change on the SYMs.  Usually every other just because if I do see something there it means something.
As you note it's just another spot to create a leak and an opportunity to strip something.
Viper254
  • Moped Pirate
« Reply #6 on: May 31, 2018, 06:59:54 AM »
Me too - my 17mm 6-point spanner has saved my bacon a few times now!
Rides;
