Author Topic: How long are tire RIMS "Suppose to" last?  (Read 2054 times)
ClayMation
« on: May 30, 2018, 04:58:35 AM »
1-How long are tire RIMS suppose to last and
2-What sort of 'abrasions' should you be concerned about when you see them?
3-What kinds of damage can pot holes cause?
Thanks.
Viper254
  • Moped Pirate
Re: How long are tire RIMS "Suppose to" last?
« Reply #1 on: May 30, 2018, 09:26:36 AM »
When you say tyre rims, do you mean the wheels?
I'd expect the wheel to outlast the bike.
Worry about cracks, if they're there I would scrap the wheel.
All sorts. Bends on the sealing edge and cracks are the common ones.
Rides;
Suzuki GW250 Inazuma (2016)
Honda C70C (red, 1983)
« Reply #2 on: May 30, 2018, 11:12:58 AM »
Curious, why do you ask?
You have abrasions......from the wheel doing what?
MJR
« Reply #3 on: May 30, 2018, 01:22:14 PM »
This is what a pothole did to one of the rims on my '03 B650.
« Last Edit: May 30, 2018, 01:29:03 PM by MJR »
'03 Coast Cyan Atlantic 500
'14 White MyRoad 700i
'09 Mirage White Burgman 650
ClayMation
« Reply #4 on: May 31, 2018, 05:01:52 AM »
The Metal RIM the tire goes onto.
ClayMation
« Reply #5 on: May 31, 2018, 05:02:44 AM »
Something on my front RIM that appears to be an abrasion or 'crack' in the paint on the outside of the RIM. I haven't determined yet.
ClayMation
« Reply #6 on: May 31, 2018, 05:03:11 AM »
Dumb question but, did you ride it like that after it happened?
MJR
« Reply #7 on: May 31, 2018, 05:33:00 AM »
Photo?
I had to limp it back to a ranger station to call a tow truck. The rim was split so the tire was flat (not holding air). Oh and I hit the pothole so hard it triggered the tip over sensor so it would barely run for a bit until it reset itself. The pothole had a abrupt edge to it, when I hit the brakes (about 40 mph) the front suspension was compressed so the tire/rim took the abuse. Doesn't look like much does it.
« Last Edit: May 31, 2018, 05:34:42 AM by MJR »
stuo
« Reply #8 on: May 31, 2018, 06:08:55 PM »
I once hit a hub cap at 60 mph that bent both front and rear rims such that I had to replace them. Aluminum wheels are easily cracked or bent. If it's bent your tire won't rotate perfectly even though it holds air. Replace it!
Don't take chances on dodgy tires, wheels or brakes is my motto. A broken clavicle taught me that lesson.
2009 GV 250
ClayMation
« Reply #9 on: May 31, 2018, 09:43:51 PM »
Photo?
Where is the photo upload option? Is the only way to first upload it to an external site and use image embed codes?
If so, how 2006.....
ClayMation
« Reply #10 on: May 31, 2018, 09:46:05 PM »
How much for a new front RIM?
hypophthalmus
« Reply #11 on: June 01, 2018, 03:09:02 AM »
When you reply to the thread, you'll see "Attachments and other options". Click on the arrow, and you'll see a button to browse for the image file.
gwdoiron
« Reply #12 on: June 17, 2018, 01:13:13 PM »
That's kind of sad.  If you hadn't been on the brakes when you hit the pothole, you might have just kept on driving.
Of course, I hit a similar pothole @ 70mph, and it broke the muffler pipe, the muffler, and damaged the steering column bearings/races.
For the OP, rims "should" outlast the bike.  Only an accident, collision with road debris, a pothole, driving on flat tires, pretending its a trials bike, or the like should cause a rim replacement.  They simply don't wear, at all, in normal operation.
« Last Edit: June 17, 2018, 01:17:25 PM by gwdoiron »
« Reply #13 on: June 18, 2018, 01:39:02 AM »
To O.P.....
Rims last decades unless you hit something.
ClayMation
« Reply #14 on: June 18, 2018, 03:07:56 AM »
What do you mean by "Pretending it's a trials bike"?
