Author Topic: what jet size should I install?  (Read 2073 times)
vermiselle
« on: June 01, 2018, 02:05:26 PM »
For my Kymco Like 50 I ordered a new 19mm carburetor because the original 16mm works badly.
My engine is original 49cc but without restriction (exhaust, air filter...)
In my original carburetor I have # 90 hand jet and # 35 pilot and work fine.
With my new 19mm carb, what jet size should I install?
Keep the #90 and #35 or increase?
Thank you!
mclark999
Re: what jet size should I install?
« Reply #1 on: June 05, 2018, 11:01:58 PM »
Thank you!
Which 19mm carb did you buy?  I just bought a Dellorto PHBG 17mm for mine and don't know quite where to start on the jet size.  I want to start rich, not lean, if possible. I got a TrailTech TTO to measure cylinder head temp to help me tune it. I'm going to start with a 78 or 80 main jet and see.
2007 Kymco People 50 2T
Tecnigas Trek exhaust
OEM 16mm carburetor
eamartin
« Reply #2 on: June 06, 2018, 03:57:28 AM »
mclark,  please tell me again, what were the symptoms of your stock carb which prompted you to purchase a Dellorto?  eamartin
mclark999
« Reply #3 on: June 06, 2018, 01:53:25 PM »
I could never get it to start easily cold AND run well and start easily hot. With the Dellorto, I can choke it it as needed and adjust the carb more precisely.  That's the theory at least.
Sent from my VS988 using Tapatalk
OEM 16mm carburetor
eamartin
« Reply #4 on: June 06, 2018, 04:08:44 PM »
Thanks for the reply.  My Super 8 2t has the stock PB Keihin carb.  If I run it daily, it starts easily and runs well.  If I let it sit for more than a day it is next to impossible to start (kick or majic button).  Great compression and crankcase holds vacuum and pressure.  Less than 2000 mi.
mclark999
« Reply #5 on: June 06, 2018, 05:15:53 PM »
Yeah, cold weather starting and sitting both seem to be issues with these. One work around that sort of worked was to set the idle a little lean and then put my hand over the air filter snorkel to choke it more to get it to start.
OEM 16mm carburetor
