Author Topic: Just a quick Hello  (Read 1461 times)
herbiedriver
Just a quick Hello
« on: June 04, 2018, 04:31:50 PM »
Just wanted to jump in and say hello...
Picked up a 2001 People 50 2t over the weekend for $50.  Didn't run, needs work but not too bad.  Got it running after cleaning the carb and fixing the kick starter (the C clip popped out and allowed the entire mechanism to slide in).
Runs pretty good, need to clean the carb again and trace some electrical gremlins, one of which I am guessing might be a ground issue.  Bike won't rev on the stand unless I hit the brake lever, then it will rev and drop off.
Not too new to scoots, I have 3 Honda Sprees that I have rebuilt from the ground up and several Chinese GY6 50cc that are general beaters.
Re: Just a quick Hello
« Reply #1 on: June 05, 2018, 12:58:49 AM »
Does "herbiedriver" have anything to do with VW bugs? We got a guy here, Stig, who has vast experiences with those! Welcome to the nut farm! Sounds like your $50 prize has a fuzzy ground. You find and fix that and it won't Rev when the brake is pulled!
herbiedriver
« Reply #2 on: June 05, 2018, 02:07:12 PM »
Yep, Herbiedriver is due to my fondness for VW's...
I currently have three in the stable, a '64, '68 and a '73 convertible...
I fixed the revving while brake is pulled, seems the wiring needed to be sorted out, cleaned and reattached grounds and added a ground strap to the engine from the frame, once that was done the bike will rev like normal.  Now I need to drain the old oil, I think the PO put some synthetic outboard motor crap in there, it smokes like a mosquito fogger and has that smell... but it runs!
« Reply #3 on: June 05, 2018, 10:04:03 PM »
Outstandong! Don't tell Stig you have those cars! He will be there drooling..I think!
mclark999
« Reply #4 on: June 05, 2018, 10:45:32 PM »
Welcome to the forum. It will be nice to have another active People owner on here.  I'm still working out gremlins on mine. Gave up for a year and now back at it. Just got a bunch of carburetor parts and will get working on it soon.
2007 Kymco People 50 2T
Tecnigas Trek exhaust
OEM 16mm carburetor
