Author Topic: amber or chrome bulb for the front turn signal.  (Read 898 times)
ModChiP
« on: June 05, 2018, 01:26:14 PM »
dt 300 2014.
second-hand
can i use amber for the front turn signal instead of chrome?
it originally came with chrome bulb in the front turn signal.
https://www.bike-parts-kymco.uk/kymco-motorcycle/assignment_spare_parts/34905LEA7E00
ophelia
Re: amber or chrome bulb for the front turn signal.
« Reply #1 on: June 05, 2018, 05:23:17 PM »
I don't see why not if the bulb base and wattage are the same. Do the factory bulbs have a chrome cap to force light to bounce off the reflector light housing before heading forwards?
I wonder if it's a stylistic thing or if it affects the light pattern enough to make a difference. I imagine regular amber bulbs are much cheaper.
« Last Edit: June 05, 2018, 05:25:09 PM by ophelia »
2011 Kymco Downtown 300i
ModChiP
« Reply #2 on: June 05, 2018, 06:40:53 PM »
"I wonder if it's a stylistic thing or if it affects the light pattern enough to make a difference"
me too.
netlag
« Reply #3 on: June 05, 2018, 09:39:42 PM »
Have read that the flasher lamps tech is called dichroic interference coating. Allows for look to be chrome, but emites amber colored light.
BAUS15 is available in amber version Sylvania #7507, Philips #12496 on the web for under $4 each.
The Diochrioc (chromed) version is Sylvania 7507LDA
under $8 each.
Have read  here that people are using LED, but lost the links.
« Last Edit: June 06, 2018, 04:01:23 AM by netlag »
2012 Kymco Super 8 50cc 2T (KF10AA)
- Position Light Mod (US)
- Derestricted OEM Exhaust
« Reply #4 on: June 05, 2018, 09:59:54 PM »
Those "chrome" bulbs in the DT300I are actually duds and the lights are wired as DRL. The Europeans and other nations have headlight switches to turn off the high current drain for starting. These chrome bulbs are for looks only. You want them to light you need only to replace with single filament bulbs or LED. You want them to work as turn signals you gotta rewire!
netlag
« Reply #5 on: June 06, 2018, 11:21:04 AM »
What does DRL mean?
« Reply #6 on: June 06, 2018, 12:42:16 PM »
Sorry! Daytime Running Light (s).
