Author Topic: Clutch Plate Replacement  (Read 2096 times)
Robertchanger
« on: June 09, 2018, 07:07:46 AM »
My Venox rattles while in third gear so I skip it and go directly to fourth.  Previous owner has been doing this for several years and runs okay he says.
Question is: should I be worried about other effects?  I am thinking I need to replace the third gear friction plate - are other brand clutch plates (like a honda rebel) compatible with the Venox transmission?
hypophthalmus
Re: Clutch Plate Replacement
« Reply #1 on: June 11, 2018, 04:20:59 PM »
Not familiar with the Venox particularly, but shouldn't all the gears use the same plates?
Besides sounding terribly inconvenient, the things I would watch for is avoiding lugging the engine and extra clutch wear by having to stay on the clutch for longer. Otherwise, it doesn't care what gear you're in.
star667
« Reply #2 on: June 24, 2018, 08:59:21 PM »
The gears are not plates that is the clutch assembly you are talking about and they would be the same for all the gears I think you might have an issue with 3rd gear only
Robertchanger
« Reply #3 on: July 07, 2018, 07:08:29 PM »
So by gear assembly you mean the gear cam stopper and spindle?  Wouldn't that effect all the gears and not just the third gear?
