Author Topic: How to disable the kick stand stop/kill switch (Downtown 300i/350i)  (Read 6355 times)
mousejunks
As we know putting the side stand down stops the engine. However you can easily disable this feature by simply unplugging the black connector (coming from the stand switch) and plugging it into the matching disconnected connector (3 green wires) already included on the same wiring harness.
« Last Edit: July 30, 2019, 10:11:54 AM by mousejunks »
'09 Kymco Espresso 150i
'17 Kymco Downtown 350i ABS
mousejunks
Re: Disabling the kick stand switch
« Reply #1 on: June 10, 2018, 05:51:35 AM »
Photo below
EvilTessmacher
« Reply #2 on: June 10, 2018, 03:15:54 PM »
But why would you want to do that?
It's a massive safety breach, to be able to start up with the sidestand down. If you do that, the bike very easily can and will run away from you, without you on it.
I vigorously advise against it.
Two things to consider...
2018 Kymco 400i - "Diana"
2013 Honda PCX - "Natasha"
1982 Honda PA-50
ophelia
« Reply #3 on: June 10, 2018, 04:09:35 PM »
Interesting write up. I prefer to have kickstand safety though. I once owned a Kymco Bet and Win 250. It didn't have the safety.
I let a friend try it in a parking lot so he could experience a world of firepower beyond his factory Ruckus. I think there were six of us waving and yelling at him to bring the kickstand up. He thought we were just excited until he attempted a left turn.
He saved it though to his credit. Bet he wouldn't make that mistake again.  ;D
2011 Kymco Downtown 300i
« Reply #4 on: June 10, 2018, 08:21:40 PM »
Me, too, sorta wonder why. 'Course I'm older these days when I forgot and nearly lost it. I don't know if I could save it these days. What REALLY sucks is when a dealer preps a DT300I for sale and does not check this feature which was in op and I catch it on pre-ride inspection. Then he tosses it off to "that is done at the factory" excuse!
ophelia
« Reply #5 on: June 10, 2018, 11:09:50 PM »
I don't understand dealers and mechanics that don't get me what I paid for in the line-item mandatory pre-purchase inspection. It's usually some non-trivial amount of money too.
mousejunks
« Reply #6 on: June 11, 2018, 12:18:19 AM »
Kymco had decided to include this feature from the factory, so it was designed to do this, even if it is less safe.
However I like to think of it as a easter egg - functions of the bike that aren't described anywhere in the owners or service manual but you simply discover them. These include:
- The fuse for the glovebox cig socket.
- The coolant drain bolt on the water pump.
- The oil drain tube on the air filter box.
- Changing the headlight globes by simply reaching into the gap behind them.
- The copper contacts on the 12V 8A relay to mark output terminals.
- The battery warning light coming on when the battery is under 12.0V. In cars it comes on when there a charging issue.
kneeslider
« Reply #7 on: June 11, 2018, 03:36:50 AM »
Mouse,
Can you please advise further on this:
- coolant drain bolt on the water pump
Thanks.
Sent from my HUAWEI VNS-L31 using Tapatalk
2019 Yamaha X-Max 250
EvilTessmacher
« Reply #8 on: June 11, 2018, 04:09:22 AM »
Mouse:
If you could also expound a bit more on the headlamp removal thing too...
On my old PCX, I had to take body panels off to get to the headlights, before I discovered that they could be reached by going up underneath from the wheel-well area. Problem with that was not enough grip was possible with the hand position necessary to reach, so I couldn't generate any turning force. That is, until I made a tool to fit over the bottom of the headlamp. Cut a circle out of some 1/2" thick hard plastic, and demeled out the shape of the bottom of the bulb. Worked like a charm. If I can do this to the X400i, it will simplify things when it comes to bulb upgrade.
Your thoughts are most wanted on this topic!
1982 Honda PA-50
kneeslider
« Reply #9 on: June 11, 2018, 04:26:45 AM »
Mouse:
We have the Downtown. To get the main headlight beam bulbs, you can reach in from underneath. If you look from underneath, you can see the rubber back cover, pop that off and you can use your fingers to turn the bulb out.
mousejunks
« Reply #10 on: June 11, 2018, 09:19:55 AM »
Mouse,
Thanks.
Here is a photo of the coolant pump. Notice the 3 outer bolts holding the pump to the engine block. The centre bolt (silver) is the coolant drain bolt. Simply remove this bolt to drain all the coolant (except the reservoir).
mousejunks
« Reply #11 on: June 11, 2018, 09:31:47 AM »
Mouse:
In the DT300i you can simply reach behind the headlight assembly and pop off the round rubber cover. The bulb can then be taken out by twisting it anticlockwise.
kneeslider
« Reply #12 on: June 11, 2018, 09:52:18 AM »
Thanks Mouse,
Is this the lowest point for the radiator cooling system?
mousejunks
« Reply #13 on: June 11, 2018, 10:50:19 AM »
Yes.
« Reply #14 on: June 11, 2018, 11:38:48 AM »
I have no fear of the side stand causing my scoots to leave without me.
I do not want to employ any more switches which could fail and leave me stranded at the donut shop! So, did not connect side stand swich on my Piaggio. Will advise if I  ever find it AWOL!
(Many scoots do not have this switch)
STIG
« Last Edit: June 11, 2018, 11:44:25 AM by Stig »
