Author Topic: How to disable the kick stand stop/kill switch (Downtown 300i/350i)  (Read 5404 times)
EvilTessmacher
Re: Disabling the kick stand switch
« Reply #15 on: June 11, 2018, 03:15:33 PM »
In the DT300i you can simply reach behind the headlight assembly and pop off the round rubber cover. The bulb can then be taken out by twisting it anticlockwise.
I hope they're close, as this will be most excellent!
I'm going to have to get up off of old rusty and go outside to look now.
Thank you!!
Two things to consider...
2018 Kymco 400i - "Diana"
2013 Honda PCX - "Natasha"
1982 Honda PA-50
kneeslider
« Reply #16 on: June 12, 2018, 01:41:53 AM »
Mouse,
One more question...... Where is the top up inlet for coolant?
Here is a photo of the coolant pump. Notice the 3 outer bolts holding the pump to the engine block. The centre bolt (silver) is the coolant drain bolt. Simply remove this bolt to drain all the coolant (except the reservoir).
2019 Yamaha X-Max 250
mousejunks
« Reply #17 on: June 12, 2018, 03:16:41 AM »
The radiator/coolant fill cap is located behind the windshield. You can remove the windshield and the front access panel to get to the cap.
'09 Kymco Espresso 150i
'17 Kymco Downtown 350i ABS
kneeslider
« Reply #18 on: June 12, 2018, 04:39:40 AM »
Ah. Thanks Mouse.
Def be a project for the weekend.
Sent from my HUAWEI VNS-L31 using Tapatalk
ophelia
« Reply #19 on: June 12, 2018, 05:30:03 AM »
If it's simply coolant top-up you're after, then the coolant recovery bottle should be under a plastic panel with a Phillips screw under the rubber flap by the left footrest.
2011 Kymco Downtown 300i
kneeslider
« Reply #20 on: June 13, 2018, 08:18:05 AM »
I'm going to attempt a flush.
mousejunks
« Reply #21 on: June 14, 2018, 12:38:12 AM »
A coolant flush is pretty straightforward:
1) Open the radiator cap
2) Open the coolant drain bolt and drain
3) Empty the plastic coolant reservoir
4) Put everything back and fill with deionized water
5) Run for a few minutes and cool down
6) Empty again and fill with 50% coolant
7) Run the engine with the radiator cap off and sqeeze the hoses to burp trapped air
8) Done
kneeslider
« Reply #22 on: June 18, 2018, 01:37:30 AM »
Thanks Mouse, can you remember how many liters of water I will need?  I will have to get to the shop to buy some distilled water.
8) Done
mousejunks
« Reply #23 on: June 18, 2018, 04:02:30 AM »
The total coolant capacity is 1.7 litres.
    Radiator: 766 cc
    Hose: 169 cc
    Reserve Tank: 590 cc
    Total capacity: 1719 cc
kneeslider
« Reply #24 on: June 18, 2018, 08:27:00 AM »
Thanks.
mousejunks
Re: How to disable the kick stand stop/kill switch (Downtown 300i/350i)
« Reply #25 on: July 30, 2019, 10:59:08 AM »
Just some more updated pics for to disable the kick/side stand
« Reply #26 on: July 30, 2019, 01:35:41 PM »
Ain't that neat?
mrbios
  • 2005 Kymco Grandvista 250cc
    • My YouTube Channel
« Reply #27 on: July 30, 2019, 04:40:57 PM »
I don't understand dealers and mechanics that don't get me what I paid for in the line-item mandatory pre-purchase inspection. It's usually some non-trivial amount of money too.
$400+ for "dealer Prep"....
PaulC
stuo
« Reply #28 on: August 04, 2019, 10:23:21 PM »
If you leave the side stand down and are able to start the engine then you can do some serious damage to yourself by taking off, then turning left: you will be pole vaulted by the side stand, possibly off the bike. I had an early Gold Wing that caused me to change my undies after that happened to me due to forgetting to put the side stand up.
2009 GV 250
« Reply #29 on: August 05, 2019, 06:12:16 PM »
Fun-ones are the owner's manuals that state that you have a side-stand lock out....when you actually do not!
One day you might discover this, on your LIKE200i.
