Author Topic: Cooling fan runs all the time with the key on  (Read 1861 times)
MJR
« on: June 11, 2018, 05:41:37 AM »
Another project I tackled earlier in March. I noticed when turning the key on when the bike was cold that the cooling fan would run. I got down and unplugging the coolant temp switch screwed into the lower radiator noticed the fan would turn off so I had a bad temp switch (at least it failed on vs. not which would have led to the bike overheating). I was out of the electrical warranty coverage period but figured I'd ask Kymco USA which thankfully mailed me out a new switch no charge. This is the same switch used on several Kymco models. I swapped out the switch myself and all is back to working as it should.
'03 Coast Cyan Atlantic 500
'14 White MyRoad 700i
'09 Mirage White Burgman 650
Viper254
  • Moped Pirate
Re: Cooling fan runs all the time with the key on
« Reply #1 on: June 11, 2018, 06:54:48 AM »
Good to hear it was an easy fix!
Rides;
Suzuki GW250 Inazuma (2016)
Honda C70C (red, 1983)
