Author Topic: 150x service light on?  (Read 4798 times)
tngo
« on: June 19, 2018, 12:16:16 PM »
Anyone knows what the service light up on my dashboard means?
Re: 150x service light on?
« Reply #1 on: June 19, 2018, 12:56:57 PM »
How is your scooter behaving?
When you turn the key on is a light blinking on the display?
If blinks are long and short it is giving you a fault code.
A maintenance manual can decipher those codes.
Maybe cyclepedia.com has a manual for this scoot?
tngo
« Reply #2 on: June 19, 2018, 01:42:30 PM »
The scooter drives normal. No blinking light. Just light just stay on. I just changed oil, gear oil and so. Have not check carb and valve though.
« Reply #3 on: June 19, 2018, 08:31:13 PM »
If scooter running fine and np blinking codes....maybe try disconnecting battery for 5 mins. See if light comes back on.
tngo
« Reply #4 on: June 20, 2018, 03:53:12 AM »
Disconnected the battery for more than 5 minutes, still that service light is on.
« Reply #5 on: June 20, 2018, 01:34:10 PM »
Does owner's manual mention this light in connection with oil change times?  If so, there would be a re-set procedure.
Hopefully another owner will offer suggestions here.
Have you talked to a Kymco dealer?
tngo
« Reply #6 on: July 16, 2018, 06:31:10 AM »
Took it to the dealer, they took a test ride. Saying probably light from the main board spreading to it. Nothing to worry about it. Thanks.
« Reply #7 on: July 21, 2018, 04:14:02 PM »
I agree with the dealer (all right! Don't faint!) based on your picture. Did the dealer explain how the service light worked? How to reset it?
tngo
« Reply #8 on: July 21, 2018, 10:02:27 PM »
Well, the service light was fully on by certain miles. The mileage even flashed before the service light. I had to hold the adjust and mode button to turn it off. Now the main board is back looking like the picture. But of course, when I first bought the scooter new, I never saw that light spreading to the service light area.
