Author Topic: Possible transmission problem? Take off Symptoms.  (Read 3130 times)
ClayMation
« on: June 22, 2018, 09:02:52 PM »
Hi guys,
Strange symptom.
Upon take off at between 0-15 mph I get a lot of vibration on the front end.
So much that it caused the straighter valve in the air valve stem to become lose and leak air.
Potential causes? What part of the transmission might be affected if it is in fact a transmission issue?
Thanks.
Re: Possible transmission problem? Take off Symptoms.
« Reply #1 on: June 22, 2018, 09:23:02 PM »
Straighter valve or Schrader valve? You mean the little spring valve thingy that screws into the tire valve stem?
ClayMation
« Reply #2 on: June 22, 2018, 09:44:05 PM »
Yes, the valve inside the air valve stem where you pump air into the tire.
But that was just a side detail, the main inquiry is regarding transmission. I have an appointment for a diagnostic next weekend but want to go in there armed with knowledge.
Any idea what are some common causes of low end throttle vibration?
« Reply #3 on: June 23, 2018, 12:29:22 AM »
My thinking....
Big-time clutch chatter?.....after 15mph clutch locked up and chatter gone?
Front end vibration - and you say it is caused by something in the rear, "the transmission"?  Clutch pads glazed might be the easiest and least expensive  to fix....unless belt is failing.
« Last Edit: June 23, 2018, 12:33:02 AM by Stig »
MJR
« Reply #4 on: June 23, 2018, 02:15:00 AM »
Mine was pretty bad, possible.
'03 Coast Cyan Atlantic 500
'14 White MyRoad 700i
'09 Mirage White Burgman 650
ClayMation
« Reply #5 on: June 23, 2018, 02:39:07 AM »
My thinking....
The drive Belt was prematurely replaced at 10,000 miles, and there was only minor glazing on the original belt. That was about 1500 miles ago. I highly doubt it's the belt.
ClayMation
« Reply #6 on: June 23, 2018, 02:39:47 AM »
Well, would you care to share the solution you came to?
MJR
« Reply #7 on: June 23, 2018, 03:22:17 AM »
Assuming thats it, http://www.kymcoforum.com/index.php?topic=26145.0
ClayMation
« Reply #8 on: June 23, 2018, 03:32:59 AM »
Thanks MJR.
Would you be willing to help me determine if this is the case?
I could drive out there next Friday if you're cool with it.
I just don't know how to take stuff apart and all that.
MJR
« Reply #9 on: June 24, 2018, 01:43:43 AM »
Thanks MJR.
I don't get home till around 5pm.
ClayMation
« Reply #10 on: June 27, 2018, 07:35:16 AM »
Would it be inconvenient to you if I got there around 5:30 or 6:00?
If so just let me know, don't want t bug you. I also wanted to see if you felt anything wrong with my bikes performance.
MJR
« Reply #11 on: June 27, 2018, 12:50:59 PM »
That would be fine.
ClayMation
« Reply #12 on: June 28, 2018, 07:51:33 PM »
That would be fine.
Okay I will message you.
ClayMation
« Reply #13 on: July 01, 2018, 07:03:11 AM »
Thanks again MJR!
It was great to visit you.
« Reply #14 on: July 01, 2018, 12:15:56 PM »
Thanks again MJR!
Hello here!?
What did the Doc say? Eveything copacetic now?
