Did you miss your
activation email
Scooters - Big Bore
Xciting 500
Clutch nut size
Topic: Clutch nut size (Read 1066 times)
Zurg1960
Newbie
Clutch nut size
June 23, 2018, 06:21:23 AM »
Could somebody please tell which is the size of the big nut which holds the clutch together?
'16 TGB Bellavita
'06 Xciting 500
'14 MyRoad 700i
Re: Clutch nut size
June 23, 2018, 11:56:44 AM »
Some people use a large crescent wrench. Hold the clutch in your hands with the wrench on that nut, and tap the wrench handle on the ground. Pops loose the nut. Then feet on the clutch to keep pressure, and remove the nut.
xsel777
Re: Clutch nut size
June 23, 2018, 01:02:52 PM »
As Stig says.
Last Edit: June 23, 2018, 01:04:40 PM by xsel777
Zurg1960
Newbie
Re: Clutch nut size
Reply #3 on:
June 23, 2018, 02:35:40 PM »
Thanks for info!
But the *size* of the wrench?
'16 TGB Bellavita
'06 Xciting 500
'14 MyRoad 700i
xsel777
Re: Clutch nut size
Reply #4 on:
June 23, 2018, 09:56:36 PM »
I went and bought one off gumtree. It is as long as my arm.(60cm) Currently it is locked in the cellar, so I unfortunately cant tell you the jaw size.
Last Edit: June 23, 2018, 09:58:53 PM by xsel777
xsel777
Re: Clutch nut size
Reply #5 on:
June 23, 2018, 09:58:06 PM »
I remember I was first trying to find a socket that size, and 48mm is bouncing around at the back of my mind.
Back
