Author Topic: Upgrade Options for 2011 People 50 4T  (Read 2241 times)
cakeod
  • DavidSEMAJ
« on: June 28, 2018, 06:02:12 PM »
I recently acquired a 2011 People 50 4T (US version) from a friend who moved out of state and was wondering what upgrades were out there.  I'm not expecting much performance from a little 50cc, but it's in my nature to tinker with all of my vehicles, so I can't just leave it stock  ;D .
Where would you guys recommend starting down the path of upgrading?
I was thinking about starting with an unrestricted CDI, but I wasn't sure which one to get for a 4T.  The only one that I can seem to find that says its for a 4T and DC is this one:
www.scooterdynasty.com/cdinarakuracingfor50cc-125cc4-strokekymcoscooters.aspx
It seems like its a lot more expensive than most other unrestricted CDIs out there, do you guys know if there are better and/or cheaper options out there that I could use?
I assume that an unrestricted variator boss and different weights/springs would be a good upgrade as well.  What parts would you recommend using on this particular scooter?
Any recommendations for exhausts or air filters?  I know changing these around would probably require a re-jet and a tune, but I figured those would be good mods to do before I go all out and upgrade to 80cc or something.
Peopless50
Re: Upgrade Options for 2011 People 50 4T
« Reply #1 on: August 22, 2020, 08:40:13 PM »
This is a bit late answer, but all GY6 parts are ok.  It will get more horsepower from a bigger cylinder and cylinder head.  Everything must be from the same system. Original cylinder head cannot be used(69mm valves). A better camshaft can be added.  Good thing in Kymco People is these big wheels, they handle much better than 12 or 13 inch wheels.
