Author Topic: 2007 Venox 250 valve adjustment  (Read 753 times)
Steve Sutton
« on: June 29, 2018, 04:50:40 PM »
Love my Venox.
I went to adjust my valves at 19000 km per Manuel.  Engine was cool but not cold,,book says Celsius and converted to Fahrenheit approximately 95 or colder. Couple hours after turning engine off but not overnight cold.  Valves we're very tight .1 mm,,,,all valves exhaust and intake,,,some so tight couldn't get .1 mm gauge inserted into gap. Anyways, adjusted valves to .1 mm,,,,put everything back together and now can hear a valve tap noise on number 1 cylinder.  Should I go back in and make the clearance a "really tight" .1 mm ?,,,,,,or,,,,,should I insert .1mm feeler gauge and tighten the nut till no slide of feeler gauge and just pull the gauge out for a super tight .1mm clearance ?  On first attempt I used .1 mm gauge and adjusted till feeler gauge made the squeaky sound,,,but am thinking that was too loose and now have a valve tapping sound.  Not sure what to do.  Is the .1mm valve clearance qouted in Manuel correct valve clearance ?.
Thanks for any advice.
BTW,,, did I mention I love this bike ? /-)
hypophthalmus
Re: 2007 Venox 250 valve adjustment
« Reply #1 on: June 29, 2018, 05:34:48 PM »
The feeler gauge shouldn't be incredibly tight in the gap. There should be some resistance, but it should also slide easily.
Steve Sutton
« Reply #2 on: June 29, 2018, 06:08:31 PM »
Thank for the reply,,,
That is what I did,,,,and now have a valve tap noise.
Could it be I didn't wait long enough and the engine was still too warm to do the adjustments ?
Or just more likely that it was the gauge "operator",,,,, me,,,,, error /-),,,,
This is my first time doing this,,,,,,had a fairly experienced bike buddy showing me how and checking my work.
If it was you,,,,,would you pull it apart and try again ?,,,,,or live with the tap noise.
Thank you for taking the time to read this newbie post in the first place,,,
« Reply #3 on: June 29, 2018, 06:22:25 PM »
It is easier if you are an old, deaf guy!  Motorcycle engines with fins, especially aluminum fins are noisy. Your gap may be a bit large but that is better than too small! Small or no clearance invites burned valves. Just do it, say every 1000 miles and you will get better. Everyone has a different "feel" for the drag on "feeler gauges" so you will be able to develop yours through practice. Also, if you think it is too big or you may could have done it better, do it again!
hypophthalmus
« Reply #4 on: June 29, 2018, 06:23:38 PM »
It looks like the manual actually says anything below 35C is fine for the engine temperature. So that's probably fine.
Did you check it again after you tightened the adjustments down?
Personally, I'm paranoid enough that I would check it again. If they're all adjusted to spec... then I don't have any more advice to offer.
Steve Sutton
« Reply #5 on: June 29, 2018, 07:04:28 PM »
Thank you for the replies,,,,
I'm working on the old deaf part ! /-)
Yes,,,I checked before buttoning it up,,,,but it  was over 100 outside in the shade and getting hotter so I think I just got it wrong.
The feeler guage set is bulky,,so I'll remove that one blade and I should get a better feel .
Thanks again for the fast replys.
Wishing you guys safe rides. Q
« Last Edit: June 29, 2018, 07:08:47 PM by Steve Sutton »
Viper254
  • Moped Pirate
« Reply #6 on: July 02, 2018, 08:54:04 AM »
Hi Steve,
I wouldn't worry too much about a light tap if you think you've set them correctly. A lot of bikes have them too tight from factory :)
Rides;
Suzuki GW250 Inazuma (2016)
Honda C70C (red, 1983)
Steve Sutton
« Reply #7 on: July 21, 2018, 03:42:39 PM »
Thank everyone for the replies,,,,
I went in and checked the valves again,,,,they were all correct,,,,,
My buddy , ( I got the Venox from him) suggested I check the cam chain tension,,,,,,low and behold after adjusting it the noise was gone.
Long live the Venox !
