Author Topic: Countershaft Seal  (Read 2213 times)
brichant
Countershaft Seal
« on: July 08, 2018, 05:07:20 AM »
How compatible with the Honda Magna 250 are our Venox's? I'm having a tough time locating a countershaft seal but I have the Honda part number for the Magna and they are both 34x52x9. Any help would be appreciated.
Re: Countershaft Seal
« Reply #1 on: July 08, 2018, 12:26:12 PM »
The part number you quoted are the dimensions of the seal: inside, outside and thickness, not necessarily in order.
brichant
« Reply #2 on: July 08, 2018, 04:54:19 PM »
Thank you, Crossbolt. I was aware of that. The Kymco number is 91022-KED9-900 and the Honda number for the VT250C is 91205-KT7-003. Both seals are listing the same dimensions that you pointed out so I'm hoping they're the same seal.
Viper254
  • Moped Pirate
« Reply #3 on: July 09, 2018, 08:59:09 AM »
Hopefully you should be fine if the part numbers match. Good Call on going for a genuine Honda seal!
Rides;
Suzuki GW250 Inazuma (2016)
Honda C70C (red, 1983)
hypophthalmus
« Reply #4 on: July 11, 2018, 06:26:57 AM »
Is there anything written on the seal that you can look up?
The dimensions are the most important thing for compatability. I seem to recall that there might be other features in these seals that might vary, but it's been a while. But like bolts, they aren't brand specific.
hypophthalmus
« Reply #5 on: July 11, 2018, 06:38:02 AM »
If there is something written on it, I would look that up on ebay (or something) instead of buying a brand name seal. I think there might be cross compatible markings as well; if so there's probably some kind of table somewhere.
