Did you miss your
activation email
Offroad
Mongoose
Mikuni 32 VM on Mongoose 300
Topic: Mikuni 32 VM on Mongoose 300 (Read 1648 times)
cummins6.7rob
Newbie
July 11, 2018, 11:43:41 AM »
So I removed the stock carb and put on a mikuni 32 vm carb so I could remove the lid to my daughter’s air box, and I am happy with the results. Has anybody done this also and what jetting are you running?
traylwp
Newbie
Re: Mikuni 32 VM on Mongoose 300
January 19, 2019, 03:23:23 PM »
Did you ever figure out the jetting for the vm32 carb? I've put a HMF full competition exhaust and aluminum airbox with trx250r K&N airfilter so I'm flowing alot more air. Been rejetting the CVK32 carb and been having some luck but not completely solved yet. The throttle response is just not what I would like it to be.
Marky
Newbie
January 22, 2019, 02:40:27 PM »
Hi . I have a mxu250 ( basically the same engine ) . I have removed the small 22mm Keihin standard carb and fitted a 30mm copy. Also fitted a foam high flow airfilter and opened up airbox. 122 size main jet and needle one groove richer works well
Last Edit: January 22, 2019, 02:47:50 PM by Marky
Back
