Author Topic: Will not start  (Read 2460 times)
MarcusB
Will not start
« on: July 12, 2018, 08:17:26 AM »
My ZX Will not start. The sparkplug is moist, and has got spark.
I can only measure halfe the recomennded preassure in cylinder (4kg cm2)
What would be the mest step recomended? Can the reed’s be faulty?
eamartin
Re: Will not start
« Reply #1 on: July 12, 2018, 11:38:27 AM »
When was the last time the machine ran correctly?
MarcusB
Re: Will not start
« Reply #2 on: July 12, 2018, 05:36:07 PM »
I dont know, i got it for free...
Will not start with Ethergas either.
I have followed the service trouble manual, and got stuck on the compression.
How can i test if the spark is good enough?
Re: Will not start
« Reply #3 on: July 12, 2018, 07:11:27 PM »
Comes sion test fails. Now find out why:
2x: rings stuck or broken, cylinder scored, hole in piston, restricted intake, restricted exhaust, reed valves staying open or closed, rotary valve broken or out of time
4x: valves staying open, valves burned, cam not turning, hole in piston, scored cylinder, restricted intake, restricted exhaust, rings stuck or broken
eamartin
Re: Will not start
« Reply #4 on: July 12, 2018, 10:56:46 PM »
That's clearly ridiculously low compression.  I'd remove the head and cylinder to have a look at the cylinder, piston and rings.
MarcusB
Re: Will not start
« Reply #5 on: July 13, 2018, 04:35:49 AM »
Thanx, i ordered new gaskets and rings just inncase Will brand it down soon. Will let you know asap
MarcusB
Re: Will not start
« Reply #6 on: July 23, 2018, 10:24:15 AM »
The piston had a little hole, the rings where broken. But the cylinder was ok, so i changed Pistons and rings, and all the gaskets. Started right away.
Thanx!
Re: Will not start
« Reply #7 on: July 28, 2018, 08:56:54 PM »
 ;D
