Author Topic: That "All-Important 600 Mile Service" is here!  (Read 2301 times)
Viper254
  • Moped Pirate
Re: That "All-Important 600 Mile Service" is here!
« Reply #15 on: July 17, 2018, 07:10:07 AM »
Oh I get it now. So I am assuming they are more of a motorcycle/powersports dealer that sells some scoots too, but is more specialized in the motorcycle/powersports kind
Of place right?  There are some of them around here.  But I am lucky and
Have a place called scooterville, though you still don’t want to bring it in there for service all the time.
I can confirm it takes ten minutes to remove ALL of the plastics surrounding the seat bucket, and the same to reinstall them.
Rides;
Suzuki GW250 Inazuma (2016)
Honda C70C (red, 1983)
« Reply #16 on: July 17, 2018, 11:20:51 AM »
I agree that you can get to the valve cover in @10 mins or so. But ALL the plastic surrounding the seat bucket???
Please shoot a video of that happening!
EvilTessmacher
« Reply #17 on: July 17, 2018, 12:04:15 PM »
Well, I have to say I absolutely did not expect all of this.
Not only have you guys "added to the paranoia" but you've made me downright fearful.  ;D
So, I'm going to order the parts and do it all myself now. I really don't want to have to spend more buckage than I have to, since the summer is a little more thin than other times, but the 600 isn't as complicated as I expected after re-reading the service manual and maintenance schedule with all of this in the forefront.
Sigh... I have to wait until the end of the month now, because of work schedule. I'm off from August 2 until the 19th. Maybe now I can get those auxiliary lights hooked up at the same time.
Two things to consider...
2018 Kymco 400i - "Diana"
2013 Honda PCX - "Natasha"
1982 Honda PA-50
Viper254
  • Moped Pirate
« Reply #18 on: July 17, 2018, 12:29:45 PM »
Challenge accepted
Rides;
leomagnus
  • Providence, RI
« Reply #19 on: July 17, 2018, 12:38:12 PM »
ET, just change the oil and transmission fluid. That's what the tech told me at the Kymco headquarters. I did that and the 400 purrs like a kitten. Clean the puke tube also if it is needed.
Dean
Rome, Italy
'97 Honda SH50
'98 Aprilia SR50
'01 Gilera Runner 180
'05 Honda SH150
Warwick, RI, USA
'12 Kymco People GTi 300
'18 Kymco Xciting 400i ABS
'22 Kymco AK550 ABS
« Reply #20 on: July 17, 2018, 01:35:58 PM »
You have made the absolutely SAFEST decision! You will KNOW it has been done right and your conscience will be crystal clear! You will big in the long journey of knowing your machine's inner-most secrets.
« Reply #21 on: July 17, 2018, 05:42:31 PM »
Dean
That's all that's really needed.  The Owners manual for my 2009 Super 8 did not call for it's first valve check until 2500 miles.  All I did was change the oil.  At 2500 the valves where still good.  I have made some minor adjustments to the valves over the years but I'm pretty sure that if I had never touched them the motor would still be running fine after 30,000 miles.
Later Super 8's called for valve checks at the 600 mile service.  Why?  They used the same engine.  I think they just wanted to let the dealers make some $$$.
I did my all my own servicing but if I wanted to take it to the dealer he told me it was around 90-100 bucks.
EvilTessmacher
« Reply #22 on: July 18, 2018, 02:08:43 AM »
Could someone please translate "Puke Tube" to Standard English?
I don't see that term anywhere in the Service Manual.  ::)
1982 Honda PA-50
« Reply #23 on: July 18, 2018, 02:18:57 AM »
Is it the airbox drain tube?
Clear tube hanging down, somewhat in view, with a black cap on it.  Remove the cap to drain the congealed oil mist crud. (I do it at oil change time)
« Last Edit: July 18, 2018, 02:24:54 AM by Stig »
« Reply #24 on: July 18, 2018, 01:02:23 PM »
You will know why we named it "puke tube" when you drain it the first time!
EvilTessmacher
« Reply #25 on: July 19, 2018, 04:43:03 AM »
Stig, if you're asking me what it is, then you're asking the wrong guy. I've never heard the term.
Karl, I'd have to know what it was, and where it was, to be able to clean it, to know why it's called what it's called.
So don't keep me in suspense... What is it?
1982 Honda PA-50
« Reply #26 on: July 19, 2018, 01:07:48 PM »
Yes, 'tis the drain tube from the airbox, collecting a foul mix of gasoline, oil and other secret ingredients before they are sucked into the throttle body. The cap on the end has a spring finger clamp which holds the black plug in the tube. This plug needs removing periodically to drain the disgusting collection. Kymco has gotten very frugal on how much tubing they use since the Yager so you really have to look for it. It should be just forward of the CVT case, up out of sight.
Forbes1964
« Reply #27 on: July 19, 2018, 02:12:46 PM »
One word of caution: make certain that you keep all receipts for the oil , filter (if applicable), and fluid that you purchase to do the services. If there is a problem that occurs under warranty , you’ll need these as PROOF that the necessary maintenance has been performed. Oh, take a picture (and date it) of the ODOMETER READING when you perform the service . There’s nothing more frustrating than having the manufacturer ask for proof of maintenance, and you have LOST the receipts.
Truth be told, if you are one (like myself) who is prone to losing little odds and ends receipts, , it may be worth it to have the service done at the dealerships,so it will be in their files too.
2009 Xciting 250
Forbes1964
« Reply #28 on: July 19, 2018, 02:19:21 PM »
I work at a Ford dealership. When our manager has implied to a customer that lack of maintenance, improper maintenance, or a “hatch job” may be responsible for the premature failure of a component on their vehicle, the thing that usually shuts the discussion down allows the customer to hear the words “ok, It will be covered under FORD Warranty “ is  “well, Y’ALL did all my services , if anyone messed it up, Y’ALL did. “
2009 Xciting 250
EvilTessmacher
« Reply #29 on: July 19, 2018, 10:13:09 PM »
Argh... More stuff to worry about now~!!
1982 Honda PA-50
