I recall you modifying your battery lid to take that taller battery. Has it been 5 years already?! Wow, how time flies! That should spin that Like engine real quick, chop, chop! That is the same cca I stuck in the DT after the "white label" cheapo started failing after two years. Works way better and if it lasts...well, we will see how long it lasts. Not a Yuasa.
