Author Topic: Should I need to put medium strength threadlocker adhesive  (Read 794 times)
ModChiP
« on: July 17, 2018, 08:37:49 PM »
Should I need to put medium strength threadlocker adhesive when changing the brake pads?
 it it recommended?
dt 300 2014.
second-hand
tnx!
Re: Should I need to put medium strength threadlocker adhesive
« Reply #1 on: July 17, 2018, 08:50:17 PM »
Loctite blue should do it.
boo
what ever you do,
« Reply #2 on: July 17, 2018, 10:13:09 PM »
Do not use Red Loctite.
I had a hell acious experience with it.
300GTI black
Pro 2A - member GOA & NRA
« Reply #3 on: July 17, 2018, 10:15:15 PM »
Red is strong. I think it is Studloc!
kneeslider
« Reply #4 on: July 18, 2018, 01:46:28 AM »
I have changed about 6 sets of front pads, never used any threadlock on that locator pin.
Are we supposed to use it as good mechanical etiquette?
2019 Yamaha X-Max 250
« Reply #5 on: July 18, 2018, 02:09:51 AM »
I use a thread lock whenever I see it on a part that was tightened at the factory. If I don't see evidence of it from the manufacturer then I don't apply any.
« Reply #6 on: July 18, 2018, 01:03:45 PM »
Now, that makes good sense, Stig!
ModChiP
« Reply #7 on: July 18, 2018, 06:09:06 PM »
thank you all!
Should I apply copper grease on the  back of the pads?
« Reply #8 on: July 18, 2018, 08:44:50 PM »
Is that the goo that is used to keep pads from squealing?
kymcogrampa
« Reply #9 on: July 19, 2018, 05:08:29 PM »
As stig has stated, I look for evidence of factory applied blue thread locker. It is a safer bet to use some on brake bolts, but it is harder to remove the bolts later. Make sure to use a 6 point socket the next time you service your brakes. This way you stand a better chance of not rounding out your bolts!
I usually use "Neverseize" in the back and sliding parts of the brake pads. It consists of aluminium powder and oil. I would like to use something better if it exists.  I will look up this copper grease...thanks ModChip.
Rene
Scooters = great smiles per gallon.
mousejunks
« Reply #10 on: July 20, 2018, 12:47:11 AM »
Greasing the back of the pads reduces noise,  but it's the sliding pins inside the caliper that are the most important.
'09 Kymco Espresso 150i
'17 Kymco Downtown 350i ABS
