Author Topic: Kymco City 125 rear bulb replacement?  (Read 1281 times)
118118
« on: July 20, 2018, 08:47:09 PM »
I'm replacing the indicator bulbs on my city 125 (2014) for LED ones. I'm trying to remove the rear light lens to get to the bulbs. I've removed the 6 screws that hold the Lens but it's still tight. It may just be stuck to the seal but i don't want to force it if there is something else holding it.
Any ideas? ???
118118
Re: Kymco City 125 rear bulb replacement? SORTED
« Reply #1 on: July 22, 2018, 11:51:18 AM »
All sorted. The rear light lens has obviously never been removed and it was just stuck with the foam seal. A bit of wiggling and extra force and it came away  :)
One thing to note: the front indicator/winker bulbs are different to the rear.
Fronts are a clear bulbs with opposed pins
Rears are Yellow bulbs with offset pins
Now just waiting for the LED relay to arrive to stop the double speed flashing  ;)
« Reply #2 on: July 22, 2018, 08:09:12 PM »
You had to answer your own question 'cause none of us knew!
