Author Topic: More Quick Fist uses  (Read 768 times)
Dayooper
« on: July 23, 2018, 02:28:00 PM »
Geared up a few more quickfist's so she'll hold my 9' & 10' catfish poles in the those hard to reach cat holes :) The quickfist minis work great for smaller poles and the tip sections while the original quickfist is a good size for larger handles at the reel seat portion.
From previous post:
    I bought the Original Quick Fist Clamp from amazon
    added a conduit hangar - which on the 450i you need 1-1/4 for the cross tubes in the back and 1-1/2 for the main roll cage
    Make sure you buy the ones with a smaller hangar hole - I tried using the cushioned conduit hangar from Grainger but they only come with a welded 3/8 nut. Not only does it not seem secure due to seating depth and the forces that will be put on it but the 3/8 hole you put in the quick fist clamp takes more material than i'd like from it.
    add #10 bolt, nut & washer
    I glued a piece of scrap ratchet strap inside the eye of the hangar so that it wasnt metal on metal
    all done
It works better than the pvc tube holders I had in the bed. The rods stuck up too high when riding and having them lay at a more horizontal angle in the bed took up too much room.
Anywho - figured I'd share as there was some experimentation w/ different parts and a few back and forth trips to the local hardware store to get it right.
airshot
Re: More Quick Fist uses
« Reply #1 on: July 23, 2018, 05:27:27 PM »
Many thanks, just love good ole homegrown enginuity!!
« Reply #2 on: July 23, 2018, 11:47:28 PM »
are those one piece rods that can't be separated for transport ?
Dayooper
« Reply #3 on: July 24, 2018, 05:18:35 PM »
yea, all 1 piece.
« Reply #4 on: July 26, 2018, 04:41:03 PM »
yea, all 1 piece.
yowza, can't imagine transporting a 10ft one piece,  my rods are all 4 sections
