Author Topic: Downtown starting problem  (Read 3952 times)
CZ99
« on: July 24, 2018, 07:25:04 AM »
Hello! I have bought my downtown 300(2014) in december and since then I had twice the same problem. The problem is when the engine is cranking and the yellow check engine light is lit on dashboard and the engine won`t start. And after a while(20min or so) it starts just like nothing`s happen. The spark plug is new, battery also good voltage, and I have no idea what is happening. Trouble is that I can`t go anywhere far now because I am afraid he will let me down and drain the battery while I`m trying to start the engine. Does anybody had similar problems? Thank you
kneeslider
Re: Downtown starting problem
« Reply #1 on: July 24, 2018, 07:33:25 AM »
Have you tried starting the bike without the fuel cap?
Sent from my HUAWEI VNS-L31 using Tapatalk
2019 Yamaha X-Max 250
CZ99
« Reply #2 on: July 24, 2018, 10:49:23 AM »
Yes I did, and I did anti-flood procedure also, I suspect it has something with the check engine light while cranking but have no idea what that could be.(there is no error code on dashboard also)
« Last Edit: July 24, 2018, 10:54:26 AM by CZ99 »
« Reply #3 on: July 24, 2018, 10:58:23 AM »
Battery perhaps not as healthy as you think?
Could you pop for a new battery at this time?
CZ99
« Reply #4 on: July 24, 2018, 11:06:17 AM »
Maybe, but after succesuful start I have tried starting a dozen times afterwards without a problem, it starts every time. Also I have put battery on charger and it was OK(2 of 4 blocks on digital charger display). Only thing that I can do is to buy a new battery and see, but it happens rarely(enough not to trust him anymore to go anywhere far from my city).
« Reply #5 on: July 24, 2018, 11:13:05 AM »
Check spark plug cap. Drain puke tube. Do you wait for self-check to complete before starting? Do all warning lights go out after it finishes self-check (except oil)? Recently my DT300i, which ALWAYS starts in two revolutions, became reluctant like yours. Battery voltage while cranking was down to 9.5 volts. Anything below 10.5 volts means replace battery.  Like Stig said, your battery is probably the culprit. Yuasa the best.
« Last Edit: July 24, 2018, 11:15:31 AM by CROSSBOLT »
CZ99
« Reply #6 on: July 24, 2018, 11:27:21 AM »
I did all you mentioned before posting, only thing i did not measure voltage while starting. Must find voltmeter from someone before replacing my 4 year old battery. By the way, how many years have past since replacing factory battery and/or replacement battery?
« Reply #7 on: July 24, 2018, 11:39:46 AM »
A new, good quality battery gives nice confidence for long out of town rides.....even if it doesn't fix your current issue.
Many batteries last much longer than 4 yrs - but some batteries become "probably going to start", rather than "going to start and get me home" after that age...especially with EFI engines.
A strong battery can overcome minor age related weaknesses in a starting system, I think.
CZ99
« Reply #8 on: July 24, 2018, 12:03:44 PM »
Only see YUASA YT12A-BS for kymco downtown 2009-2013, what about 2014-
« Reply #9 on: July 24, 2018, 12:47:41 PM »
Measure your battery. I will bet the 2014 is the same size. Four years? It's the battery!
« Reply #10 on: July 24, 2018, 07:16:39 PM »
Yes, measure your current battery - then look at the battery terminals orientation and type - then match it and buy most CCA you can afford to replace it with same size. Too misleading to buy scooter batteries from a list.
stuo
« Reply #11 on: August 27, 2018, 07:40:03 PM »
I'm the cheapest person I know but I don't gamble with batteries: Four years old, I would replace it.
2009 GV 250
