Author Topic: Easy way to remove a cinch/crimp hose clamp ??  (Read 613 times)
« on: July 24, 2018, 11:23:19 PM »
Is there an easier way to remove one of these cinch, or crimp, hose clamps. Thing looks like a permanent ("one-time") clamp!
This breather hose is attached with the same type clamp to the valve cover - and there is no room to do a valve lash check with the valve cover hanging about on that hose.
This short hose had to be removed in order to move the valve cover out of the away....and it was a bugger to get it cut off down in there with some side cutters.
Would there have been an easier way to unfasten it? The manner the hose is fastened on each end looks like it is never to come off?
Re: Easy way to remove a cinch/crimp hose clamp ??
« Reply #1 on: July 25, 2018, 12:23:58 AM »
Those things are dirt cheap....for the manufacturer. Replace with small screw clamps, Ideal is a good, stainless brand. Cut 'em off any way you can!
« Last Edit: July 25, 2018, 12:26:04 AM by CROSSBOLT »
« Reply #2 on: July 25, 2018, 12:33:28 AM »
This clamp was the most time consuming and hardest part of the whole valve adjustment process! As Rose-Anna Danna used to say, "It's always somethin' !"
« Reply #3 on: July 25, 2018, 12:50:49 AM »
  if you can see the end sticking out stick a flat screw driver there and tap with a hammer, it pops off then pull with a plyers
« Reply #4 on: July 25, 2018, 11:09:19 AM »
Thanks de dee, I couldn't get too frisky because it was attached to plastic.
