Author Topic: Help with no spark  (Read 8061 times)
Islandboyil
Re: Help with no spark
« Reply #45 on: August 03, 2018, 10:47:33 PM »
Here it is
« Reply #46 on: August 03, 2018, 11:57:00 PM »
OK, that makes sense. You have a machine that takes a DC CDI. Your harness has 4 wires, the diagram shows 4 wires to CDI, there is no coil to the CDI except the pulse and there is the DC wire to the ignition switch. Even the colors match what your picture shows. DC CDI.
Islandboyil
« Reply #47 on: August 04, 2018, 12:00:10 AM »
Ok. I have an unrestricted dc cdi that I will have to try tomorrow. I was wondering if it could possibly be the ignition switch??
« Reply #48 on: August 04, 2018, 01:16:52 AM »
You betcha!
Islandboyil
« Reply #49 on: August 04, 2018, 06:24:15 PM »
Tried dc cdi no spark. Tried hot wiring no spark
« Reply #50 on: August 04, 2018, 10:05:23 PM »
Assuming replacement stator including pulsar coil good then CDI defective. All parts new in box?
Islandboyil
« Reply #51 on: August 04, 2018, 10:08:56 PM »
Yes all parts new in box. Cdi was bought from eBay. I will have a new cdi ordered from kymco. Probably take a week to get. Will keep you posted
« Reply #52 on: August 05, 2018, 12:09:22 AM »
« Reply #53 on: August 05, 2018, 06:29:26 PM »
Chase down all grounds, take 'em apart, clean 'em, put 'em back together after you have ensured all terminal lugs have continuity with wire and no corrosion.
Islandboyil
« Reply #54 on: August 05, 2018, 06:34:05 PM »
Will do
« Reply #55 on: August 13, 2018, 11:00:35 AM »
You still there? What's up?
Islandboyil
« Reply #56 on: August 13, 2018, 11:04:49 AM »
Still here. Ground looks good. I ordered a cdi from Rolling Wrench Denver . It’s a dc cdi and a 1 year only model. 2 more weeks I should have it. I will let you know when I get it!!!
« Reply #57 on: August 13, 2018, 07:49:43 PM »
Alright! Just makin' sure you still breathing!
Scootmaster
  • If you're too busy to ride, you're too busy!
« Reply #58 on: February 28, 2019, 12:44:32 AM »
My 2011 people 50 isn't getting spark. Read thru this thread. Ya'll left me hanging!  :-[ Was the problem solved?
2011 Kymco People 50
2009 Kymco Xciting 500Ri
2004 Honda VTX1300S
2008 Honda Goldwing GL1800
« Reply #59 on: July 08, 2019, 10:51:23 AM »
C'mon, islandboy! No good sending personal messages! Tell everyone what it took to fix this so we all can learn!
