Author Topic: Question about fuel injection scoots  (Read 1041 times)
Snoopzilla
« on: July 28, 2018, 04:30:28 PM »
So this Like 150i is my first fuel injected scooter.  And was wondering if the same rule that applies to cars applies to this about not letting the fuel tank getting below quarter tank (I usually stick to half) for the fuel pump to be not over taxed (cooling).
2018 Kymco Like 150i
Re: Question about fuel injection scoots
« Reply #1 on: July 28, 2018, 04:47:25 PM »
My LIKE200ILX has such a small tank - so I  keep it at least 1/3  full for my peace of mind.
Your concern for keeping fuel pump submerged might be a good idea.
I dropped a larger Yamaha motorcycle pump in there 4 yrs ago, when trying to solve what turned out to be a failing TPS. ( dealer was brain-dead at the time - I diagnosed fix after reading a bike forum and testing with Kymco diag. tool from crossbolts)
Forbes1964
« Reply #2 on: July 28, 2018, 04:48:47 PM »
While it’s always nice to keep a full tank and it COULD lengthen fuel pump life, MANY automobile drivers drive with low fuel levels regularly with no ill effects getting 150,000 miles + out of their oe fuel pumps. With a scooter , I see no problem with filling it up and letting it get to 1/4 tank, so you’ll get the full use of your fuel tank. There’s no need to to through the inconvenience of constantly topping off a small fuel thank .
2009 Xciting 250
Forbes1964
« Reply #3 on: July 28, 2018, 07:22:28 PM »
The main issue with fuel injection is to make sure you use clean , quality fuel. Every so often I’d recommend using a few ounces of fuel injector cleaner
2009 Xciting 250
Snoopzilla
« Reply #4 on: July 28, 2018, 08:19:08 PM »
. But doesn’t most top tier fuel already have injector/system cleaner already mixed in?
Forbes1964
« Reply #5 on: July 29, 2018, 02:28:31 AM »
Yes, they do. But scooters sometimes operate under different conditions than automobiles, their injector is smaller. And minor deposits have a greater effect . So every so often a little extra cleaning additives may help. Not every tankful. But maybe every 5 or so. The cost is minimal given the small size of a scooters gas tank.
2009 Xciting 250
MJR
« Reply #6 on: July 29, 2018, 02:39:20 AM »
I'm not sure where this started but most have in tank fuel pumps yes but the fuel is pumped through the pump cooling it so being submerged isn't all important.
'03 Coast Cyan Atlantic 500
'14 White MyRoad 700i
'09 Mirage White Burgman 650
Forbes1964
« Reply #7 on: July 29, 2018, 02:41:00 AM »
I fully agree. Running low is not really harmful. Just don’t run dry.
2009 Xciting 250
MJR
« Reply #8 on: July 29, 2018, 03:04:58 AM »
Even if you did once the engine computer no longer sees engine rpm (crank sensor) it will shut off the fuel pump within 5 seconds.
« Reply #9 on: July 29, 2018, 02:51:15 PM »
 â€¦.the fuel is pumped through the pump cooling it so being submerged isn't all important
And that MJR....is exactly why we keep you on such a hefty retainer! :)
(See Bernice on the 3rd floor - he has your check)
I am sorely impressed with how little I know about how things work!
« Last Edit: July 29, 2018, 02:53:24 PM by Stig »
MJR
« Reply #10 on: July 29, 2018, 04:04:55 PM »
As long as you have a pit crew you only need to drive!
Forbes1964
« Reply #11 on: July 29, 2018, 08:02:21 PM »
True. If a pump fails after running dry once, it was just about to die anyway.
2009 Xciting 250
David E
« Reply #12 on: July 31, 2018, 11:57:55 AM »
I throw in two cap fills of cleaner every so often.   I never let the tank go below a 1/4 either.   One thing I’ve also done is keep a 2 gallon gas can with fuel in it for the Like.   That 2 gallon can gets fuel stabilizer in it as well.   Gets used monthly.   I don’t always get to refill the can but I do once in a while.  That’s just me.
Forbes1964
« Reply #13 on: July 31, 2018, 11:26:51 PM »
All in all, I believe you’ll find fuel injection to be more reliable, less finicky, easier to start under all conditions, and just all around better than a carburetor. The Xciting 500 with fuel injection seems to be known for cold start issues. But it’s an exception. Most of us have romanticized the carburetor because we can take it apart and fix it ourselves. But on balance, if you use decent fuel, drive it regularly, and use a little additive every once in a while, a fuel injected system is usually very reliable. Yes, IF they do give trouble, it can be a challenge to diagnose and costly to fix. But they simply don’t then to give trouble that often.
With cars, think about it. When’s the last time you had to pump the accelerator to start the car? And how often do you have a problem that’s actually traceable to the fuel injection? We used to rebuild carburetors REGULARLY.
2009 Xciting 250
hypophthalmus
« Reply #14 on: August 01, 2018, 01:22:49 AM »
I've come to realize that fuel injection actually offers quite a wealth of information for diagnosis.
Not really that costly to fix either, if you can diagnose and replace the part yourself.
For my van, all I needed was a $10 OBDII bluetooth device and $5 of software. I think I could have gotten nicer software for $30 if I weren't so cheap.
It sounds like motorcycles come up a bit short with regards to this though -- I think the proprietary Kymco tool is some hundreds of dollars for something that probably isn't as good.
« Last Edit: August 01, 2018, 01:26:11 AM by hypophthalmus »
