Yes, please don't jump to the conclusion you need a new one. You can have the old one bored to the first oversize and buy first oversize piston kit. Check for availability of this first of course. I don't know if they even make oversize for these scooters but they're usually made for every other kind of engine I've ever seen. Call a local machine shop or two and ask if they do boring. Many do and it'll be cheaper than a new cylinder. Perhaps faster than ordering a new one as well.
They will be able to advise you on the condition of your current cylinder before boring. That is, they may suggest you just have it honed slightly and, if it's measurements are still in spec, it's good. If not, or if honing doesn't get rid of the scratches, they can then bore it.
You'll have to supply them with the specs for the cylinder from the shop manual for your scooter -- usually available on line for free.
