Author Topic: Faster  (Read 817 times)
Luke2002
Faster
« on: August 07, 2018, 09:26:07 AM »
Does anyone know how to make my kymco agility 50 4t faster its derestricted and only goes 35 it’s hard to get up hills go about 10mph up hills can someone help !!!!
AlexisStarlyn
Re: Faster
« Reply #1 on: August 07, 2018, 11:32:23 AM »
Smooth boss installed?
Also a big bore, or maybe something bigger.
OaklyJava
Re: Faster
« Reply #2 on: September 10, 2018, 06:40:31 AM »
What year is yours? I have a 2015 model & i swapped out the cdi box, larger carb, air filter and unrestricted boss and I average 40-45 mph flat ground and a little over 50 mph downhill.. did good for about a week now it has no power climbing hills at all![emoji849]
Sent from my SM-G950U using Tapatalk
Re: Faster
« Reply #3 on: September 12, 2018, 03:17:47 PM »
Oakley Java, that is because you did not put a larger main jet in the carb. Being so lean you probably overheated it and either burned a valve or broke a ring. One of the restrictions is a very lean mixture....
Tromper
  • Seattlish
Re: Faster
« Reply #4 on: September 13, 2018, 03:16:10 AM »
maybe lighter rollers would help to a point, or you can do what Oakly did, but make sure you use a bigger jet, & richen the mixture a bit.
Beyond that I say do a gas cap job and install a faster scoot.  Really the best solution IMHO.
2008 SYM HD200 "Niwanibiz"
k9 S200 (Blue) "Max" (Sold)
OaklyJava
Re: Faster
« Reply #5 on: September 13, 2018, 06:12:29 AM »
No I purchased a larger carburetor with upgraded jets but I took the aftermarket variator I installed off and inspected it and the problem was there inside the variator and on the boss. (Preventing the variator to function properly).Hard to explain it wasn't dirt it was almost like gum or something very hard to clean off. Also the aftermarket roller weights were 8 grams versus the 6.5 grams stock, so I cleaned the stock parts and reinstalled them all except the restricted boss with exceptional results.
xsel777
Re: Faster
« Reply #6 on: September 13, 2018, 09:18:30 AM »
Well done OaklyJava
Tromper
  • Seattlish
Re: Faster
« Reply #7 on: September 13, 2018, 07:04:21 PM »
Ditto Xsel777.
Not sure how the gearing is on those, but since you seem to have a handle on it I'm curious if you tried running a lighter weight with that to increase revs?
My thought would be you'd lose potential top end that the bike can't really get to in exchange for actual top end.
OaklyJava
Re: Faster
« Reply #8 on: September 15, 2018, 03:44:28 PM »
Ditto Xsel777.
No but the aftermarket part I installed had 8 gram weights so I installed the 6.5 stock one back on..went smooth on my way to work but started slowing down on my way home so I'm guessing it's the crappy drive boss.
