Author Topic: Crank bearings?????  (Read 6980 times)
Jarek
Crank bearings?????
« on: August 05, 2010, 03:49:32 PM »
Any idea where i can purchase new crankshaft bearings?
Re: Crank bearings?????
« Reply #1 on: August 05, 2010, 04:05:02 PM »
.. "www.stadiumyamaha.com" ...
..best place for OEM kymco parts..
..mention this forum if you order from them...
peace
thebatman
« Reply #2 on: August 05, 2010, 04:12:23 PM »
what year zx do you have?? are you SURE the crank bearring??...01,02 were/can be bad but the 03,04 has one of the stongest, bearrings in..those usually are good to go....
"THE BAT"MAN...
Says:
Jarek
« Reply #3 on: August 06, 2010, 01:25:37 PM »
i have a 2002 and the crank jiggles on the variator side
art
« Reply #4 on: August 06, 2010, 05:33:46 PM »
  Thats a sure sign. If you have the  bearing out. Take it to a local bearing shop they will usually have what you need in stock at near 1/2 the price and twice the quality..
« Last Edit: August 06, 2010, 05:40:57 PM by art »
Jarek
« Reply #5 on: August 07, 2010, 03:32:36 AM »
thanks il look into that
sidthesloth
  • Kymco ZX50
« Reply #6 on: September 24, 2010, 12:14:35 PM »
Hey art, given that 2 strokes are in your blood, I will direct this question to you, given that this thread was about crank bearings, I think seals ought to be included. When replacing the crank seals, are they standard seals or they special seals? I am considering splitting the case and working the inlet.
art
« Reply #7 on: September 24, 2010, 07:41:56 PM »
  There is a good chance that the seals can fit from a bearing shop,but the oem's are cheap from the factory,best not to take a chance. Some have built in seals some don't. If built in should be fine. If seperated I would get the oem's. Ha! I'm almost awake! Point is it matters what kind of bearing it is.
sidthesloth
  • Kymco ZX50
« Reply #8 on: September 24, 2010, 10:57:04 PM »
Thanks art, I was just wondering about the seal construction, wether it is just an oil seal or different. If I go oem, I will have to order in advance, if I can get them from the bearing shop, I can take one down there and get one in a couple days. Other option is ebay, far quicker than oem, plus, have my eye on a stroker crank, just need the readies.
art
« Reply #9 on: September 25, 2010, 08:46:20 PM »
  Yep you need it in your hands to make the call the first time around. I havn't been in the lower half of one of these scoots yet. Once you know give us a post  :D
sidthesloth
  • Kymco ZX50
« Reply #10 on: September 25, 2010, 11:37:07 PM »
Will do. I plan on taking some pics as a reference. Should be fun.
sidthesloth
  • Kymco ZX50
« Reply #11 on: September 27, 2010, 01:56:19 PM »
The crank seals are separate, the bearing bloke had both in stock, is chasing the bearings. On the stock bearings the outer race is a lot thicker than standard, would there be a reason for this?
art
« Reply #12 on: September 27, 2010, 05:20:04 PM »
 I would think it was for clearence issues,wouldn't want the inner rubbing on anything once seated.
Did you save any cash?
sidthesloth
  • Kymco ZX50
« Reply #13 on: September 27, 2010, 10:22:36 PM »
G'day art, I was actually refering to the thickness from the inside diameter to the outside diameter.
Here's a pic.
Rianna
« Reply #14 on: September 28, 2010, 12:16:19 AM »
Now I see what them little buggers look like. 8)
