Author Topic: Crank bearings?????  (Read 6956 times)
sidthesloth
  • Kymco ZX50
Re: Crank bearings?????
« Reply #30 on: October 30, 2010, 07:29:08 AM »
One more thing. Most likely you wiped your crank out by the bearing that went bad. Check the crankshft for scoring, heat marks, and put a set of calipers to see how true it is. But I would bet you wiped the crank where the bearing sits.
lankeeyankee, had you bothered to read the post you would see that my bearings and crank were not damaged, I was looking at replacing the bearings simply because I had the engine apart, the bearings are proving to be dificult to get a hold of and on ebay i can buy a crank with bearings for about $70, or $110 for a stroker crank, with bearings.
sidthesloth
  • Kymco ZX50
« Reply #31 on: October 30, 2010, 07:34:48 AM »
Areomyst, thanks for the offer, but if I go for a new crank I will probably go with one from ebay, they are a good price and have the bearings and seals with them. Trying to buy anything for these scoots in australia is not easy. This is why I got the cylinder kit from ebay, if i remember at the time a 70cc kit locally was $339, the one I got was $135.
lankeeyankee
  • I have an attitude problem with stupidity
« Reply #32 on: October 30, 2010, 02:40:05 PM »
Chiming in again........
The first post to this topic was by jarek
"Any idea where i can purchase new crankshaft bearings?"
Where do you come in trying to correct me?
« Reply #33 on: October 31, 2010, 12:44:35 AM »
...omg...here we go again....
lankeeyankee
« Reply #34 on: October 31, 2010, 03:00:31 AM »
Am I correct or not? Jarek started the post wanting information on crank bearings.
