Author Topic: Super fever ignition problem?  (Read 1154 times)
Darrenb
« on: August 14, 2018, 10:04:57 PM »
Found another super fever. Engine like shuts off after few miles sometimes longer, sometimes right away. Noticed when this happens the shut off switch doesn't work correctly. Engine will start back up but has no accelerations idle then dies again. If I wait 30 min it goes away. Engine doesn't seem like it's hot at all runs great when running. Could it be the cdi?
« Last Edit: August 15, 2018, 12:08:41 AM by Darrenb »
Re: Super fever ignition problem?
« Reply #1 on: August 14, 2018, 11:54:48 PM »
I'm confused here - you are selling a Super Fever, and you have another Super Fever with running issues? Yes?
You are selling the one which "runs as it should" ??
Darrenb
« Reply #2 on: August 15, 2018, 12:05:23 AM »
I just got the one with problem yesterday,
michaelboone.7447
« Reply #3 on: October 28, 2018, 12:13:38 AM »
Sounds like cdi that's where I would start I have a question where (country) r u from all these scooters seem the same but with different names I'm in the USA do these scooters have the Chinese 139qmb engine in them
Sent from my LM-X210CM using Tapatalk
